home built lathe duplicator
>I've never been a fan of these things, mostly because of the scraping action. I can't believe you could get fine details, especially sharp points. However I have a project that seemed perfect for this so I decided to see if I could build one and if it works I could play with it and see what kind of job it does.
I searched all over the net and found 2 examples that I thought could be built easily out of wood. I modified both of course. It will be a few more days before I have it done because I have to work a long day followed by a club meeting tomorrow night.
I'll post photos and results when I get it up and working.
I have a diamond shaped metal cutting bit that I'm going to use. I don't know if this is a good choice but it's what I've got.
Re: home built lathe duplicator
Re: home built lathe duplicator *LINK*
Dick Coers
>Always like to see shop made tools, looking forward to the pics. I'm adding a link to the Vega cutter I use in my mini duplicator.
carbide v cutter
Thanks Dick
>The cutter I'm using is similar. I'm not sure it's exactly the same. Mine has a slight gullet right behind the cutting edge. This is common in carbide metal cutting bits. I can't tell from looking at the photo if that bit has that detail or not.
