Poison Ivy (OT)
Poison Ivy (OT)
Poison Ivy (OT)
Rick Pixley
>I know this is way off but most of you folks play around in the woods a little. I moved to the north about 18 months ago from sunny south Florida and really never run across this before.
Yesterday I was cleaning the fence line of my property with a brush cutter. I knew I was in Poison Ivy and thought I was prepared to deal with it,you know long pants,heavy long sleeve shirt,even in 90 degree weather. Me being the macho (aka dumb) type I thought I;d jus kick the living s### out of these little three leaved darlings and then just wash all the exposed areas in rubbing alchohol..To cut to the chase I must have absent mindedly (particular male traight) wiped my brow on those poison ivy encrusted sleeves...Needless to say, as I type this, both of my eyes are almost swollen shut.. I've tried most over the counter remedies in the past and it still took weeks to heal...Anyone out there got any secret recipes for curing ignorance induced pain? thanks,Rick
Re: Poison Ivy (OT)
A visit to the doctor is in order
Ron in Drums PA
Re: Poison Ivy (OT)
Your wing man, the one holding your Beer...
>should have warned you.
There is an over the counter salve available that might knock it out. I think it is called Zanfel. I Went to buy some a several years ago just to put it on the shelf just in case. It was in the section where they had the Cortisone. It was about $40 for a tiny amount. I left it there. Figured I would store it at the drug store until I actually needed it. Might be worth it on the week end until you can get to your doctor. Ask the pharmacist if you can't find it, but the price should tell you, just in case I got the name wrong.
Cortisone will reduce the itching of a small patch enough to wait it out for me.
There is another product I read about, but have not tried. Tech-nu. A Liquid you put on it for a few minutes and wash it off to remove the oil.
If I suspect I have it on my skin, I wash the area with lacquer thinner. It seems to work, but it might be that there was no oil there to start with.
Re: Poison Ivy (OT)
PS...
>You can Google Poison Ivy cures for home brewed stuff.
Let us know if you find anything that works.
My X wife did not catch it. I used to let her deal with it. Just one more thing I lost in the divorce.
Re: Poison Ivy (OT)
Re: A visit to the doctor is in order
Lan Brady
>Rick,
Ron is right, dont mess with that stuff around eyes, ears, nose or throat. See the Dr.
Next time you get around it. Take a tub bath using laundry detergent. Rubbing alcohol is not a strong enough base to neutralize the poision Ivy acid.
Good Luck with your recovery, Lan
Re: Poison Ivy (OT)
Re: Poison Ivy (OT)
Rick Pixley
>update...Looked up Zanfel and it appears to be the only known chemical that will remove the poison from the skin and can be applied at any time after exposure...Called my Pharmacy and 40 bucks an ounce...ouch,thats a couple cases of beer...(sorry wingman)...called my doc and she laughed..(what's so funny?) The website for zanfel states if you believe it has reached the bloodstream of other systems (evidenced by swelling and no rash) then the only treatment is a prescription steroid,in this case prednisdone(sp?)...I'm gonna get both and test it again in the woods today..A brilliant man once told me there is a fine line separating balls and brains,usually defined as PAIN...
Re: Poison Ivy (OT)
Rob Wallace
Re: A visit to the doctor is in order *LINK*
Rob Wallace
>Just to clear-up some misconceptions about the why and how of Poison Ivy...
The toxic chemical is an oil found in members of the Cashew Family (anacardiaceae) called urushiol. (This is not an acid!) When this oil is in contact with the skin (or other body areas, including mucous membranes) severe irritation (and likely immune response, tissue swelling, itching, etc.) results. Much of this happens when the urushiol oil invades sweat ducts and hair follicles (which include skin oil [sebacous] glands), inducing these responses which can be painful. Subsequent blistering, skin reddening, intense itching, etc. can follow in particularly susceptible individuals.
Part of the reason why poisonvivy is difficult to treat through home remedies is that once the oil is in the sweat glands and hair follicles, it is difficult to remove through topical cleaning. Some say that application of rubbing alcohol actually worsens the insult to the skin becuse it helps spread the oil to other areas or body parts. The topical use of clamine lotion and other agents that serve to absorb and sequester the oil are often effective.
In this case, particularly when eyes and mucous membranes are involved, immediate professional treatment is obviosly indicated. Do not wait! Do not waste time trying home remedies. The immune response will lilkely intensify unless some medication is administered soon to reduce the immune response and attempt to continually remove the irritating oil as it is expressed from the sweat glands and through the normal production of skin oils (sebum).
Hope this helps!
Rob Wallace (at AAW in Albuquerque)
[Not a medical doctor, but often consulted by local medical staff in the area about plant-induced dermatitis, etc.]
Urushiol Wikipedia Entry
Re: Poison Ivy (OT)
Nicely Said Rob
Barbara Gill, Remlik VA
>There are so many misconceptions about Poison Ivy.
Re: Poison Ivy (OT)
ebd
Re: Poison Ivy (OT)
ebd
>Definitely a Dr. fast.
For skin exposure there is a wild plant that is quick & very effective in treating poison ivy as well as stinging nettle and other types of dermic reactions.
Scientific info:
Family: Balsaminaceae
Genus: Impatiens (im-PAY-shuns)
Species: capensis (ka-PEN-sis)
Common names:
Jewelweed
Glassweed
spotted impatiens
wild impatiens
I've included a picture. It grows in damp areas usually on the edge of woods. Flowers are either yellow or orange. The seed pods pop when touched if they are ripe.
Crush the main stem and rub the juice on the affected area. The itch will stop almost immediatly. Also, if you run into stinging nettle impatiens will always be growing nearby.
I've also used varieties of balsam and New Guina Impatiens from the nursery with success.
Re: Poison Ivy (OT)
Re: Poison Ivy (OT)
>I did not include this is my post above, but I have used this plant many times. Known about it since I was a kid. Did not know the name of it. Called it "Touch me Not" because the seed head do Burt and throw the seeds. (Take a look at them, interesting. like coiled springs.) It worked for me, but I did not know how to tell anyone to find it. And it does smell like impatiens.
Re: Poison Ivy (OT)
Re: Poison Ivy (OT)
Emmett Manley, Lakeland, TN------WebKitFormBoundar
>There is no effective specific treatment for poison ivy dermatitis. Without complications the dermatitis usually reaches a peak 4-7 days after initial exposure then improves rapidly. The therapeutic goal is to prevent infection and provide relief from the itching and discomfort. Over the counter hydrocortisone cream is about as effective as anything available, but local anesthetic creams and/or oral antihistaminics may be needed to provide relief from the itching.
Most of the real serious cases of poison ivy dermatitis involve people who exhibit marked sensitivity to the resin and who have widespread exposure or who inhale burning poison ivy leaves or vines. These cases are usually treated with systemic steroids.
People differ markedly in their sensitivity to poison ivy. The nature of the reaction is not well understood as no antibodies are formed and there is really no way to protect sensitive individual. And sensitivity to poison ivy may change over a lifetime -- most people become less sensitive, but some become more sensitive.
The worst case I ever had was the result of using a chainsaw to cut small trees with poison ivy vines -- the saw blast went through my shirt and my entire torso was effected. A horrible week followed.
Please remember that the dermatitis is a reaction to the toxic resin -- the dermatitis does not spread, although the lesions may not all appear at once, as they can develop over a period of a few days, probably reflecting differences in skin thicknesses.
Good luck.
I am a retired medical school pharmacoologist/physiologist and one who had a special interest in the toxicology of natural products -- plants, venoms, mushrooms, etc.
Re: Poison Ivy (OT)
Re: Poison Ivy (OT) It's a Miracle
Rick Pixley
>As an update I took just one of the prednisone pills and used a cvs brand duplicate of Zanfel wash and the pain has gone,the swelling has disapated,and the redness is disappearing almost fast enough to watch. The wash is half the price of the Zanfel and I had the Pharmicist look at both and compare,he stated the ingredients had different chemicals but with similar characteristics and the cvs contained a larger amount of water. I could live with it at half price and it worked...Now to put it to the acid test,Back to the woods..
Re: Poison Ivy (OT)
Poison Ivy in Eyes ...Treatment
Doc Green
>The best treatment I've found for poison ivy in or around the eyes is a solution of boric acid. Powdered boric acid is available from a drugstore. Mix it in warm water, one tablespoon of powder to a pint of warm water. Give it a few minutes to dissolve. (Read directions on label.)
This doesn't sound good ... putting acid into your eyes ... but the solution makes a good eye wash. I've used it for years.
The way you use it is to saturate a small cloth (handkerchief or washcloth)and place it over your eyes while lying in front of a stereo with Pavarotti playing. This may be a bit more of a hassle that you want to admit to, but if you've got poison ivy really bad, you won't mind at all.
The solution can also be used on other "sensitive areas" of the body.
As you know, the problem with treating poison ivy around the eyes is getting the medication INTO your eyes. Therefore, home remedies such as calamine lotion, Clorox, salt and buttermilk, cannot be used.
I've not used it myself, but I've worked around other people who swear by the Tech-nu stuff that keeps you from getting the rash after exposure.
If you're concerned about using the boric acid solution in your eyes, and you should be, as your pharmacist or other health professional.
Good Luck. ~Doc (not MD) Green PS: If you don't have Pavarotti, Beverly Sills will work just as well, maybe better.
Re: Poison Ivy (OT)
Pavarotti
Ken Oakley-Sunny St. Cloud, Fla.
>I have many CD's by him but, my preference in woman would be Sarah Brightman. I second the boric acid, though I have never had Poison Ivy. I think I have an immunity to it.
Re: Poison Ivy (OT)
Brad Vietje
Re: Poison Ivy (OT)
Brad Vietje
>Best of luck, Rick,
I don't know what you mean by "north", but one of the benefits of living up as far as I do(~45 miles from Canada) is that the only things I need to worry about in the woods are poison ivy and annoying insects like black flies, deer flies and mosquitoes. We have no poisonous snakes, spiders or other creatures, and only on extremely rare occasions does someone come between a bear cub and its mama, or finds a baby moose with its protective mom. Running into a 1500 pound bull moose during rutting season could be a little dicy, but that's also quite rare.
We also have had a pretty dramatic increase in non-native invasive plants, some of which are quite toxic, like Water Hemlock and Giant Hogweed.
Oddly enough, I saw my first Vermont wild Black Bear just yesterday morning, on the way to a job site. A little fella, probably a year old, and around 80 pounds -- went cavorting across the road about 30 yards ahead of me on a relatively quiet dirt road. I've seen full-grown bears in Maine and NH, but had never seen a wild bear in VT.
I hope your poison ivy incident is something you can laugh about soon. Sounds like you were lucky, in a way -- you really don't want to breathe in the dust and particles when weed wacking the stuff and get it in your lungs, either!
Safe spinning,
Brad Vietje
Newbury, VT
Re: Poison Ivy (OT)
ebd
Re: Poison Ivy (OT)
ebd
>Beg to differ. I've used the remedy that I've suggested on myself and a number of others. It works. There may be no pharmacy item that works but Impatiens does!
Re: Poison Ivy (OT)
Re: Poison Ivy (OT)
Bill Crommett
>How lucky we are nowdays ! As a kid I used to chase the other kids with a handfull of poison Ivy leaves. (rotten kid !) I was immune until one day in the early forties I was cutting weeds for a farmer and somehow got into some poison ivy. The local doctor prescribed Tincture Of Ferric Chloride for my hands, both ankles and one leg up to the knee. A week later I got out of bed and got dressed and bought the land-lady some new sheets. Times and treatments have changed -- for the better.
Re: Poison Ivy (OT)
Re: Poison Ivy (OT) Cure for pain
Mike Jones in Redding, Ca.
>I have had a great deal of experience with urushiol dermatitus. Out here in the wild west it's poison oak, rather than ivy, but the oil is the same.
I know of nothing that will remove the rash once the reaction to the toxin has begun, but, (and you'll have to trust me here) you can stop the itching/burning without professional or medicinal help. What I offer here may sound like a cruel hoax, but there is science that explains why it works.
Here is what to do: Hot shower...as hot as you can stand until your body acclimates to that temperature, then turn the hot up just until you can just stand it...acclimate again, then turn it up again. It will require about 20 minutes at temperatures elevated to the "painful point" but once done, you'll get as much as 8 hours of itch free relief. In some cases, the relief is permanent. Here's why this home remedy works.
The itching is caused by histamines and these histamines are produced by our bodies. Full body emersion in very hot water and for these durations, will shut off the production of histamines and the itching stops.
(The shower is reccomended, tub bath is not.)
Re: Poison Ivy (OT)
Re: Sarah Brightman
Don Evans
>You have excellent taste Ken. Sarah and her "Time to Say Goodbye", just doesn't get better than that. Easy on the eyes also.
Don
Re: Poison Ivy (OT)
Thanks Emmett
>Seems like we have plenty of professionals on the case here. I just thought I would relate my poison ivy history, in case there is anything useful for anyone...
When I was a kid, I used to get poison ivy really bad -- we're talking red welts filling up with fluid, then popping and spreading the dermatitis (if that's the term) everywhere else it went. One year, before sending me off to summer camp, my folks did two things for me. First, they started me on a regime of poison ivy pills called AntIvy (as I recall -- this was more than 50 years ago). I took the recommended dose for however many days it specified. Second, they took me to the doctor for poison ivy shots. I have no idea what was in those shots. All I know is that for the past 50 years I have been able to touch, chainsaw and burn poison ivy with only the occasional mild itching that goes away in a day or so.
I don't know if this entitles me to any conclusions, but I suspect you can build up an immunity to this urushi oil or whatever the active ingredient in poison ivy is. I'm sure the science has come a long way since the 50's, so if there's anything to it, maybe a doctor or immunologist can help you avoid the next episode. I feel for you.
Ellis Walentine, Host
Re: Poison Ivy (OT)
Re: Poison Ivy (OT)
Rick Pixley
>To me anything north of Georgia is considered.I ended up in Chester county,PA. It is absolutely gorgeous here and as others have stated, in the woods there are very few varmits to worry about..Not at all like Florida where it seems everything will either poison you or eat you.
Mybe it's just my own experience but it seems there are things on the market that will help cure the reactions to this poison ivy.This morning I have no redness at all, no itching or burning,the swelling has gone away mostly, and I generally feel great. When talking with the doc she has a standard protocol they use here and it consists of 20mg prednisone,with progressively smaller doses over three weeks,and the use of commercial cleaners. In my case I used cvs pharmacy's generic one that is a clone of a popular and expensive variety.the clone also is expensive at 20 bucks(compared to 40) an ounce but worth every dime as far as I'm concerned. I also uused tenru wash late last night and didn't rinse it off,just let it cook as it immediately relieves tha pain and allowed me a good night's sleep.
I believe my biggest mistake in handling the ivy was not wearing gloves and that will be remedied immediately. If there are any more reactions or news I'll report back as this seems to be a fairly common occurrence. Thanks to all for the great advice, war stories, and humor, after all life is like a roll of toilet paper,the closer to the end you get,the faster it goes....
Re: Poison Ivy (OT)
Jerry Louden
Jerry Louden
>If you have exposure on a small area, a hair dryer will work to stop the itching. I know several friends who have tried it and it seems to work. Just don't burn yourself.
Re: Poison Ivy (OT)
Neutralize it......
Michael Stadulis in Southern NJ
>I'll relay what we did in geology field trips in college. Our professor required each of us to have a spray bottle filled w/ his recipe. We filled it with a solution of non-sudsy ammonia mixed w/ water. We used 10 parts of water to one part of non-sudsy ammonia. Keep spraying yourself as the day goes one. the ammonia is a "base" and our prof said that the poison ivy oil was acidic so the ammonia neutralized the acid oil components. Worked for me.
Re: Poison Ivy (OT)
Re: Thanks Emmett
>Maybe that is why it doesn't bother me. When I was 7 or 8 years old on a dare from the neighborhood bully I ate some poison ivy leaves. I could roll in the stuff and never get it.
Re: Poison Ivy (OT)
Re: Neutralize it......
Bill Crommett
>There used to be (twenty years ago) a cream/ointment available in either a water soluble or a solvent soluble base that we used to prevent the irritating effects of Ivy/Oak/Sumac, that was also used for those working with exotic woods. I recall that a demonstrator at the Chatahoochi woodturners monthly meeting used this because he was allergic to
Cocobola. I don't recall the name of the stuff, and it is not a senior moment because I couldn't remember the name 15 years ago when I needed some.
