Acrylic pen blanks, what to expect?
Brian in Brighton
>I am playing with turning more and more and bought a couple of acrylic pen blanks. They seem very hard. Is there any tips you could offer on what to expect when I turn these blanks? They are square and a lot harder than the woods I have been playing with.
I did hear that I should use micro-mesh for polishing. Is there soemthing different about the tools that I should know?
Brian in Brighton
Re: Acrylic pen blanks, what to expect?
Chip in Plano
>My 2 cents....
They tend to stink up the joint. Always mark the blank on the outside so you can orient the piece correctly. This is more evident on acrylics than some woods.
I have turned with various tools but the best is still a very sharp skew. Watch out for the ribbons of plastic as you peel them off. They can wrap around the mandrel and they will slice you up if not careful.
Most tubes are brass. Sometimes, the brass can reflect through some acrylic blank colors when turned down thin like on a slimline pen. This mottles the appearance some. Tubes also come in different metal colors from the big catalog suppliers. You can also paint the tubes lightly with color found in your blank. Scuffed the tube up first.
Or instead of turning flush to bushings, you can leave the acrylic a little proud/thicker at the areas where the brass might show through.
For gluing tubes, don't drill the hole and immediately try to glue the tube in. The hole in the blank will still be very hot and the CA glue will setup quicker than you can shove it in correctly. Wait a few minutes. I use a thin CA in the hole first and try to get a good layer all around. I use thick CA on the tube and shove it in with a twisting motion to spread/fill any voids.
I personally don't like acrylic but I cannot argue that women and kids like the patterns and the color variety. I only due them as special requests and as gifts at work for my project team after successfully implementing a client. I like to turn wood bowls, HFs more.
Also, I use my Jet Mini for pens instead of my PM.
Jim Rutten
>Chip's response was excellent. In addition, take your time. It is going to take longer than a wood blank even to get these round let alone even with the bushings. Stop your lathe occasionally and clean up the shavings that are revolving around it. Keep your tools sharp. Lastly, when I get down close but not quite to the bushing I "round off" the end (I do this with acrylic and wood). That way when you are constructing the pen there is never any danger of the material overhanging the kit or underhanging it. It always is a smooth transition. Finally, sand normally, to 400. Don't be discouraged by the look of the pen at this stage. I have had some real ugly acrylic pens at 120 grit that turned into something special when I got through the micromesh. Obviously, finish off with micromesh. I still prefer wood pens if given my drothers, but have made acrylics for several neices weddings and you ought to see their faces when you pull out a pen that matches there wedding colors.
Dick Coers
>A couple more tips;
Keep a little water in the acrylic as you drill the hole. The plastic can weld itself to the drill and then it's a "bull ride" to keep from hurting yourself.
You can't beat a skew for getting a good finish on acrylic. If you scrape, you will take a chance of chipping the acrylic. Some acrylic will chip as you knock off the corners, but then smooths up as it gets round.
A good plastic polish will put on the really fine finish. (That's after wet sanding up to 12000 Micro mesh.) Use something like Novus polish, or Woodcraft also sells a plastic polish.
