Lacquor cloudy
Lacquor cloudy
Lacquor cloudy
Norm Smith
>Yesterday I sprayed the fourth coat of lacquor on a few pieces. It was a very rainy, humid day which I suspect turned the lacquor cloudy. Do I have to sand out the cloudy coat or would another coat on a warm day eliminate the cloud?
Thanks,
Norm
Re: Lacquor cloudy
Re: Lacquor cloudy *LINK*
Russ Fairfield
>Typical case of blush from moisture, and we are entering the season of "blushing lacquer" in many parts of the country. High humidity is deadly on lacquer, and blush can easilly happen while spraying when it is in the 90+%.
You have 3 choices:
Wait and see if it evaporates with time. That could be a week or more.
Soften the surface with a spray coat of raw lacquer thinner to give the moisture a chance to evaporate. A retarding thinner would be better because it will evaporate slower.
Remove the lacquer if the blush appears to be permanent. Wait for better atmospheric conditions and use a retarding thinner that will evaporate slower at thisd time of the year. Brushing can be a better option if you don't want to wait. The only difference is that you will have to more time finishing the finish to remove the brush marks.
Try one of the new waterborne lacquers. They aren't as sensitive to humidity as the solvent lacquers, and the new ones burn into the previous coat, the same as the solvent lacquers. The only one I have used is that available from Stewart-MacDonald, the lutherier supply folks.
Read my article on "Lacquer" for a few tips on preventing it from happening again.
Finishing Secreta - Lacquer
Re: Lacquor cloudy
Re: Lacquor cloudy
Norm Smith
>Russ, Thank you so much for your advice. I sincerely appreciate it.
Norm
Re: Lacquor cloudy
Keith Tompkins
Re: Lacquor cloudy
Keith Tompkins
>As usual , Russ is right on the money. Spraying straight thinner is something I've done in a pinch. Careful application with a heat-lamp works, but great care must be taken to avoid ruining the finish. the new water-based finishes have come a long way!
