Polyurethane Over Watco Not Drying
Barry Turner
>I have turned 32 - 3" round X 3/4" bases (thnk hockey pucks) for chess pieces for a friend. He plans to mount various action figures on the bases to use as the chessmen. Half are figured maple, the others figured walnut. I put on a coat of Watco Danish Oil to pop the grain and let dry a couple of days. Then I sprayed a coat of Minwax Poly (from a spray can). Three days later, the walnut bases are still tacky. The maple ones dried nicely and now have a second coat. Has anyone had this problem? Any guesses as to why the walnut bases have not dried but the maple did? My guess is the walnut is more porous and absorbed more of the Watco Danish Oil. Anything I can do to accelerate the drying? I'm driving 250 miles on Sunday to deliver the pieces and the walnut still needs another coat of finish. Thanks.
Re: Polyurethane Over Watco Not Drying
Lan Brady
>Barry,
Not an expert here, I can only relate my experiece. I used tung oil when I made Lazy susans. The maple and pine dry in 2 days. Walnut, Oak, and Ash require 1-2 weeks to dry. My definition of dry is when they did not smell like Tung oil anymore.
Good Luck, Lan
Barry Turner
>I think the more porous woods take more time to dry because they absorb more oil........does that make sense?
GaryG in MD
>I'm no expert, but I would guess that the answer is "yes".
I put Watco on a side-grain turned cherry bowl a day or two before I wanted to show it at a meeting -- knowing, of course, that I was rushing it. Bottom line -- the side grain parts of the bowl dried fine and took a nice shine, but the end grain quadrants (that soaked up more Watco) continued to stay tacky and resist polishing. No surprise there. Porous woods, or the porous parts of a piece of wood, are going to need longer. I generally give Watco a couple weeks just to be sure. ...Gary
Curly Smith
>Since both tung oil and linseed oil dry by oxidation you might try placing the pieces in front of a fan. In theory, the fan would disrupt the equilibrium layer that forms over the drying surface and would accelerate the drying process. I've done this in the past but I can't actually say that it worked as I didn't use any control samples but it made me feel better because I was doing something besides watching the pieces not dry.
You could also try wiping the pieces down with turpentine or mineral spirits in a effort to remove the "excess" oil but I'm not sure what that would do to your poly. It might be best if you could strip the poly, wipe down the pieces with turpentine or mineral spirits, apply a new coat of the Watco diluted to 50% with turpentine or mineral spirits to control the amount of oil that gets absorbed, and then try the poly - if you have enough time.
