chain jumped off bar
mfoster
>I was out in my fields today clearing the small saplings and overhanging branches that interfere with mowing the fields. My mother in law, who we inherited the property from, hired out a local to mow the fields, and I am positive that he never got off the tractor. If a tree fell, he just mowed around it. It is a big job to clear the fields back to the original stone walls, and I am taking it a bit at a time.
While I was clearing some of the branches, I must have snagged a twig or something, but the chain jumped right off the bar. Never had that happen before. I checked the tension on the chain before starting, and it was right on. No harm done, thank god, but a little disconcerting. Anyone have a similar problem. Just wondering if there is anything I should change.
Re: chain jumped off bar
Ray Binnicker
>If it were a new chain I think I have the answer. A new chain, properly installed and tensioned, will tend to stretch a bit soon after cranking and using. I had several come off before learning this. I now run a new chain a short while, shut the saw off and check the tension. Most times the new chain tends to be a little slack.
My 1cents
Ray Binnicker
Thad
>Consider yourself lucky no harm was done.
Have had them catch flesh before...nothing major.
Also had them catch the little metal guard just below the spool...bent the chain..didn't have another one with me...was done for the day.
I've resolved it to be just a part of using chainsaws.
~ Thad
Keith Tompkins
Keith Tompkins
>HI Mike, Most likely, the chain was too loose...if you use a chainsaw a lot, you'll discover the chain needs tensioning frequently,sometimes every fuel fillup. When adjusting the chain, I lift up on the tip of the bar as I turn the chain tensioner. That "pre-loads" the bar. Cutting small branches, especially several at once can throw the chain. Be sure the bar rails are true and square, and the chain cannot rock side to side...that will agrivate the problem, making the chain easier to throw off.
Re: chain tensioning
>Pretty easy to throw a loose chain, especially one running on an uneven bar and/or on a saw with a worn sprocket.
"Dressing" a bar (taking the wear-bur off and squaring the rails to the bar, is pretty easy with a properly dressed grinder.
Yes, you should check the tension on your chain while in use, and adjust it accordingly. What was not mentioned was, just as on a band saw, you should take some tension off the chain when you put the saw away. As the chain gets hot from cutting, it stretches out, but as it cools it tightens up. If you leave the chain at its running tension, it shrinks and puts real stress on the links that can fatigue and fail during the next use. Throwing a loop is one thing; throwing a broken chain at high speed can be a lot worse.
You should also check your sprocket for wear. A worn sprocket won't do your chains much good either.
Lan Brady
>I can only share how the same thing happens to me. Even with a new bar and properly tensioned chain, it can jump off. On limbs I tend to not seat the wood agaisnt the powerhead, but somewhere in the middle of the bar. That is the least controled point of the chain.A little harmonic motion and away it goes.
Dont apply pressure and dont twist the bar during the cut. Chainsaws are meant to cut ONLY a straight line and at its own speed, not mine.
Good Luck, Lan
>I had that happen once when I was cutting of branches that had vines around them. A vine got under the bar probably because the chain didn't have enough tension. The vine was wrapped around the bar and under the chain.
Plenty of room for theory here
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Maybe it is like whipping a wave down a long rope or chain. Whatever,,,,,,,, It is common and easy to make happen when touching a tough / small limb or vine out near the tip, especially with a long bar.
Could your eye see the stretch on the underside while the topside sent the wrinkle out to the tip?
mfoster
>Thanks for all the help. Seems like it is not an uncommon occurrence. I am relatively sure the chain was properly tensioned. It was when I started and I did fill the tank a couple of times and there was no noticeable change in the tension. The chain was not new, so the stretch has already happened. I've had the saw for 8-9 years, and it's had a pretty good workout since then. I still have the original bar and drive sprocket. I did notice some wear on the sprocket, and will inspect the bar tomorrow for wear. May be time for a new bar and drive sprocket.
Thanks again for all the advice.
Mike
Barry Turner
>I hope that wasn't a poison ivy vine. That would have been double trouble.
Roger
>At times sawdust/chips will get pulled between the drive sproket and the chain and that can throw even a properly tensioned chain off.
Roger
