Have a question? Ask Woody!
Use for BIG Wood chipper blades?
Dominic in Bucks County PA
>Hi Gang,
I posted this on the handtool forum but thought that some of the tool makers here could provide some input.
My buddy is refurbing a BIG V-8 powered wood chipper. He bought this thing from Craigs List knowing that the previous owner had forgot to tighten one of the blade "wedges" (that clamp it in place). The head that held the blades looks amazing like a head from an ENOURMOUS Wood Jointer. I saw the remains of one blade and was amazed the the previous owner escaped unscathed. Talk about schrapnel!
Anyway, my buddy now has a couple 3" wide x 1/4" (or 5/16")thk x 16" long steel blades. I was wondering what we could make out of these things. Besides a nice heavy wood turning scraper, that is. I'd LOVE to make a plane iron or something else out of this stuff. :>)
I'm not sure what kind of steel these blades are made from. I do know that it's hard as hell and took a "shaving" out of a iron wedge (yes, like it was made of WOOD) when my buddy was dissambling the chipper. A close look with a high powered magnifying glass leads me to believe that these blades are not case hardened, but have a uniform structure thoughout.
So I'm wondering how I could cut this stuff up. What method would allow me to cut it to useable size? I'm thinking that an abrasive cut off wheel would work. But I'm concerned that it would overheat the steel. Any thoughts on this?
See ya around,
Dominic
Re: Use for BIG Wood chipper blades?
>Dom I saw an episode of big machines on TV and they were sharpening one of those. I think they were HSS but I don't remember for sure. I don't believe they are carbide but I could easily be wrong. My thoughts would be a big scraper. I think they might be too thick to make a hand plane blade.
Lan Brady
>Dom,
I have one that I added a handle. I use it to flatten the wooden chucks before glueing wood blank on.
By laying the sharp blade across the surface and applying slight pressure to the far side of the bed, it flattens the entire surface. Talk about to the nearest 10 thousanth's. (yes, I know the wood moves the instant I quit cutting). Anyhow, it works for when I make 2 piece bowls or vases in the same manner. It creates an amazing glue joint. I guess it is similar to the sanding board that Joel and Mark use for their segmented work!
Good Luck, Lan
Skip Beardsley------WebKitFormBoundarylsHY4+4w161B
>Dom,
Our club gets planer blades from a local saw mill on occasion and several of us use them to make tools. Recently I took three of these blades to a shop here in the valley which cuts steel with a machine which uses water to do the cutting. They cut the blades to the sizes and shapes I wanted then I brought them home and went to work with my 4.5 inch grinder. Made several different scrapers and a skew. The skew really turned out well and it now is the one I reach for most of the time. Several others I have, including one from Alan Lacer, now rest on the rack most of the time.
You might look for a shop like the one we have here which will make it much easier to make tools. After I got done with the shaping I cut a bolt in half and cut a notch in the end to fit over the planer blade. I then welded it so it acted as a tang. A new handle I was in business.
Got six tools for about forty bucks.
Skip
No such thing as
Dominic Greco in Bucks County Pa
>Too thick of a plane blade!!! :>) the thicker it is, the less you need a chip breaker
truthfully and I NEVER thought I'd say this, I have enough turning tools!
Thanks for the suggestion anyway
Re: No such thing as *LINK*
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Hey Dominic, Here is something that I recommend for cutting metal like this without drawing the temper. It is cheap and can be use on any grinder.
For this purpose, you can use it on your TS or cutoff saw or on your grinder, with an abrasive cutoff wheel, with this thing blowing into the cut from about an inch or two away.
You may remember a year or two that I posted a 3/8" steel bearing which I had ground half away while holding it between my two fingers, and never felt any heat.
http://www.littlemachineshop.com/products/product_
matt overton
>Dom,
when we met at the Philadelphia Furniture workshop open house, we were standing in fromt of the guy that was hand planing/scraping a 6"x10' board. Why not make some of those planes and scrapers?
Good luck,
Matt Overton
NOW we're talkin'!!!
>Keith,
GREAT idea! I can use that with an abrasive cut off disc and I'd be in business.
Thanks!
>Matt,
I remember that! It was the guy selling Japanese planes, right?
As far as scraping planes go, I'm all set already. And since I can snag some steel from the scrap bin here at work, I've got enough thin (0.005" to 0.063") 1095 blue polished steel to keep me in scrapers for a LONG time.
But I'd really love to make a HUGE jointer plane and a 55 deg smoother.
Making Woodworking Tools - class at JCC FS *LINK*
>I know Dave Smucker, he is a fellow member of the parish to which I belong. He teaches well.
Of course you have to find something to do with the wife and child.
Or you could bring them along. She might like one of the classes. There are day schools in Murphy, Hayesville and Blairsville for your child.
Making Woodworking tools.
