>Had this idea I wanted to share and maybe some of you who get more time in the shop can play with it. Inside-out turning, but make an endgrain bowl instead of an ornament or a vase. I am guessing the inside design will have to be a bit deeper, but I can't think of a reason it won't work. Should make a beautiful small bowl.
>Jim I don't have a photo handy but can do a bowl that resembles a flower with inside out turning. This is going to be hard to describe in print without a photo but you take a 4 square pieces, lets say 2x2x6, glue them together with a paper joint. Chuck them up in a 4 jaw chuck with one end free.
About an inch or so from the chuck turn them down to a cylinder. Then turn the free end round. Now break the glue joint, reverse each piece 180 degrees and glue back together. You now have sort of a flower shape on the inside. Turn the outside to whatever you want. Usually I echo the inside shape to make it appear more like the leaves of a flower.
This could be done with larger pieces and shorter and then it would be closer to a bowl shape or like a flower really wide open.
>Belden. Someone who takes things that are in your comfort zone and chucks (pun intended) them out the window. This is meant as and should only be interpreted as a compliment of the highest order. Thanks, Charlie.
>As you've experience with this inside out idea, it really isn't that hard to change your perspective to see possibilities that aren't the norm or obvious at first glance. Questioning assumptions can lead to some interesting possibilities - some which pan out - and some that don't. But inveriably, even the ones that don't pan out open up other possibilities.
One of the things I'm trying to do by sharing some Wild Hare Ideas is to get someone here to say "If THAT bozo can do THAT, I sure as hell can - at least try - THIS"
>This is part of a flower piece I did while teaching inside out turning. This is started the same way as the illustration Charlie posted. Instead of doing a bowl shape once it was reversed, I simply followed the reverse curve to create the leaf shapes.
