how to make a bunch of mirrors
>Just kidding. This is part of my last batch of mirrors. I've made about 15 in the last week and have an order for 5 more high end mirrors so I've got to get rolling on those.
beaded mirrors
>Well I don't have one of Wally's secret beading tools but I did make my own. The beads wrap all the way around this mirror. I started at the mirror side and worked my way toward the center. By shear luck it worked out to be perfect. I was going to simply leave a larger convex area in the middle if it didn't. The beads on the handle were turned with the 3/8" detail gouge.
yellow heart inlay
>I do these inlays in groups of 3. I glue up the inlay out of 3/4" material and then glue it to a blank of wood. I true up the outside and then use a custom tool I designed to cut matching tapers on the inside and outside. Then I use a thin parting tool to cut the ring into 3 separate rings.
I cut a groove in the mirror body using the same custom tool. This gives me groove with outward tapered sides that match the taper of the ring. I simply enlarge the groove very carefully until the ring sits down in the groove perfectly. It's much easier than trying to match perfectly square sides.
This is purple heart with yellow heart inlay.
which one do you like best
>When I'm doing production work I try to improve the fine details of each piece. It just turned out that out of almost 20 mirrors I made the tail end of the handle of six of them the same design. Tell me which one you like. I can almost tell you the order they were turned in by looking at them.
I think it's important to constantly evaluate your work and try to improve it. There's nothing better than making lots of something to improve both your turning skills and your eye.
Re: which one do you like best
Don at Central Illinois
>I like the third from left the best.
#6, then #4
steve antonucci
I also like #6 with #4 a close second...
Brian McKearney
Re: how to make a bunch of mirrors
WayneLeach - NW Ont
>John,
I'm impressed with your design ingenuity and variety. You do great work and I am inspired to try my hand at mirrors now.
Do you get your mirror glass cut locally or from one of the turning supply places.
Enjoy looking at your creativity and wonder how in the world you work and find the time to do turning as well?
Best regards,
Wayne
WayneLeach - NW Ont
>I like the second from the left and the 4th a close second!
Wayne
>Wayne I buy my mirrors in volume from Tripar Inc. They have a large minimum order but the prices are good if you want a whole lot of mirrors.
2nd from the left for me!
Marc Phillips
Don Orr
>4th from left for wood and shape.
Very nice work as always.
>Personally I like the 4th from the end but I think they look better when I make the transition from the ogee to the ball a little longer and thinner and then make the ball about 1/2 as big as the large diameter of the ogee. I think the most important part is the shape of the large diameter of the ogee. If the tip slops too quickly it simply looks like you didn't take the time to do it right. The same is true as you start the curve over the ogee, it has to look like it's coming out of a ball shape rather than a bead shape.
I think the lower part looks better if it has a soft curve going to the narrow part rather than just a straight line going from the large part of the ogee to the ball. This is pretty subtle but it makes a difference.
Bob Moffett
>I like #4 the best.
he sleeps one hour a week
robert davis
and that's at the office :)
