A55 Smoothing Plane
Escoulen chucks- During the class last.....
Jamie Donaldson
>...week we tried to find Escoulen chucks to purchase, but little luck. I have just received a reply from Vicmarc that a dealer in Italy has them, but apparently none in the USA? Do any of y'all know a source for these excellent toys/tools?
Re: Escoulen chucks- During the class last.....
Re: Escoulen chucks- During the class last..... *LINK*
Donna Banfield
>Jamie, the only US distributor of Escoulen's chuck (according to Escoulen's website) is Woodworker's Emporium, in Las Vegas. The link below to their site says that the 'virtual store' is closed, but the brick & mortar one is still open for business.
Give them a call, they may have what you're looking for.
http://www.woodworkersemporium.com/closed.htm
Ralph
>Their "virtual" store has been down for at least two years. IMO they have no plans to fix it.
I talked to them on this very subject in April/May. They do not currently have it in stock, but plan to have it in mid-July (I'm guessing it will actually be August)
Base price is around $350, with a full set of accessories it will run over $500
Fred Holder
>If you are going to the AAW Symposium next week, you can talk directly to Woodworker's Emporium and Vicmarc about the Escoulen Chuck. I doubt if the Italian Distributor of the Vicmarc/Escoulen chuck will be there but there is a good chance some of the chucks will be available. I was going to purchase one to do a review directly from the Italian Distributor, but the cost of the chuck plus shipping from Italy was just too much. They did say that the chucks would be available in the US by mid summer and would be less expensive than he could sell it to me with shipping.
I own all of the other Escoulen chucks and wanted this one too, but it was going to cost me over $600. That was too much to pay for a tool to test.
More Woodturning Website
Fog Tanner
>The full accesories will run you over $700. I got the price breakdown when I bought mine. Buying only the ones I really needed, it was still over $500 for the chuck and a few adapters.
Fog
Fog Tanner
>Jamie,
If you are attending the AAW symposium, you can talk to Christian about them. He is the owner of Woodworker's Emporium and the only one I know of in the US that will be importing them. I am assuming you are talking about the Vicmarc/Escoulen chuck.
They are a fun chuck to work with. I currently have a piece on mine that has 20 different axis so far, with seven more to do on the bottom.
If you get one, and want to turn bigger items you might want to look at the auxiallary weights for the integrated balancing system. On some of the things I have turned, the standard weights are not enough. I have the Vic balancing system so that compensates when I run out of balancing on the Vicmarc/Escoulen chuck. But, they would be handy when I use the chuck on my 16" lathe which does not have a balancing system and I run out of counter weight. I have used it on my 16" lathe for finials, but any of the larger pieces and the vibration is too much for safe turning.
The ball adapter (you really need that one) will let you use the balls from your Escoulen #1, which is what I have been doing. That saves a little money and lets you get started in a hurry.
Good luck in your search,
Fog
RonZ
>You can try all of the above venues to try and get Escoulen's chuck and I highly recommend it. On the off chance you can't, Sorby sells and off center chuck that does many of the things Escoulen's chuck does.
