Stumbled On A Different Means of Carving
charlie belden
>Seems I just can't avoid Wild Hare Ideas.
While working out the details of the Sperm Component of Biological Imperative - a piece with a small motorized gearbox inside (groan), to take a break I chucked up a weird chunk of wood just to turn something without a plan. The blank had knots and checks and spits and cracks - but I thought I could turn through most of them.
WRONG! The cracks and checks got deeper even as I turned to remove them - wood fibers stretching in strands acrossed the opening wood.
But some of the material around a few angled knots fell out - leaving openings into the inside of the piece - through which light could escape from the inside.
Hmmmm. . . if those cracks and checks run deep enough . . . and if I turn the walls thin enough . . . natural filigree - patterns dictated by the wood! Hmmmm.
A little work with some small dental burs, a little wood removal with a fine carving knife - hmmmm.
But there were opening checks with wood fiber spanning them in places that were too narrow for a bur or knife. So I broke out some scalpels and the handle for them and had a go at removing the fibers. Grain was just too crazy - trying to cut away one of the fiber strands created a new "up hill" bristle.
So I tried sawing them off with a fine jeweler's saw blade - but I broke a lot of blades going that route.
Hmmmm - I've got a flat shading pyrography tip that'd fit in those narrow spaces - and maybe if I crank up the heat I might be able to vaporize those pesky fibers - without damaging the outside surface of the piece much if at all (I've got steady hands and a magni-visor and worked in very small tight places making jewelry.
Surprise, surprise - it worked - vaporizing those pesky little hairs and furry areas, leaving a matt black face on the sides of the checks and cracks.
Hmmm - wonder if rather than branding a surface - if you could carve with a wood vaporizer? And if I added a foot pedal on/off switch . . .
Can't seem to esacape Wild Hare Ideas - sigh.
Re: Stumbled On A Different Means of Carving
AndiWolfe
>Charlie - I've been using a technique I call "burnt relief" for carving for nearly 10 years now. I have one example posted on the AAW gallery site:
http://www.aawforum.org/photopost/showphoto.php?photo=310&sort=3&ppuser=53
Another example is here: http://andiwolfe.com/woodturning/burntleaves.html
I need to work on my website to put my recent work up, but these two images will give you an idea.
Pyrography has also been used for piercing by many turners. It's a great technique for achieving a lot of different effects. For carving, though, I think there are better techniques than pyrography, although I do like the burnt relief motifs I've done.
charlie belden
>Andi:
When do you find time to sleep? For that matter how CAN you sleep with all those ideas for pieces that must stack up in your mind? To be as prolific as you are and create so much at such a high quality level, both in terms of concept as well as execution - amazing. To do that between treking and all the other things you're into - really amazing.
As usual, there doesn't seem to be much new under the sun. When you stumble on, or set out to create, something new, you invariably find that someone's already Been There, Done That, Got The T-Shirt, foot prints surrounding the "find", evidence that someone else got there sooner.
I had a book by a duck decoy maker who uses pyrography to do some very realistic feathers, including down (sp?) feathers. His technique for undercutting the ends of feathers to enhance the illusion of overlapping feathers made me aware of pyrographic low relief carving. And Grame Priddle's Wood Vaporization texturing technique reinforced the idea of using heat to remove wood.
But both of these techniques work on the surface of the wood. What I needed was initially just a way of getting rid of wood fibers spanning long, very narrow, checks and cracks - some going down as much as a quarter inch or more. Straight mechanical methods can't do what I was after, and lord knows I tried every way I knew of before trying the flat thin shading tip on a wood burner.
Now some of the checks in this piece are very shallow. I'd like to get them to extend all the way through the wall of this piece so light from inside the piece can escape through them as well (the piece will be internally lit with pretty bright LEDs (stick on Push On and Off Closet Light).
I know a laser engravers can do very delicate piercing, but the process, when applied to a curved surface, involves a special mounting jig with indexing involved . . . Laser piercing just doesn't lend itself to random patterns like checks and cracks in a turning - or the interactive nature of carving by hand - even when the hand is controlling a small cutting bur, spinning at ungodly speeds. This flat shadding tip on a pyrography pen holds the promise of "adaptive piercing" - the nature of the piece dictating the size and location of the piercing, the pyro-carving-tool wielder adapting to the wood's demands.
There is promise for free hand laser engraving on the horizon - dentists are using pulsing laser "drills" now - though the price of admission is still pretty high right now. But - with luck - the price will come down, or used equiptment will get into the hands of artists and craftsman, or maybe both.
(Hmmm, one of my dontists has a laser "drill". Wonder if he'd let me try it on paper first, then I'll see if I can persuade him to let me try it on some wood . . .)
Having watched Graeme vaporize patterns into one of his pieces, I see some possible improvements in the technique.
Rather than trying to place a glowing almost white hot "tip" at the desired location and then impressing it into the wood - what if you could place the tip at the desired location ON the wood - and then apply the heat - instantaneously. A foot pedal to instantly turn the power on, and a capacitor to releasing a lot of energy in literally, a flash.
I know fire has been used for wood removal, I grew up paddling a "dug out" cayuco (think a cross between a canoe and a kayak - out of mahogany) that was "dug out" by placing hot coals on the wood then scraping out the burnt and charred wood.
Hmmmm - lots of possibilities here.
That sure do look like...
>... mission olive, Charlie. The pieces I have turned have the same kinds of defects. In answer to your rumination, though, every time I use an Exacto or something else to remove slivers like the ones that are bugging you, the piece ends up looking like something is missing. My current thinking is to leave them there. Problem solved. :-)
Adapting techniques & multitasking
AndiWolfe
>Charlie - sounds like you have some fun things to explore.
Re my busy schedule - I'd be bored if I weren't up to my eyebrows in multiple tasks all the time. The key is to cycle through the activities and to not do them all in the same day.
This week my focus has been on completing a new piece for the AAW symposium. Thus, I've not played any of my musical instruments (I'll be in trouble tomorrow for band practice), I've not made an appearance at work (it's summer quarter, though, so I'm allowed to stay home if I want), and I've not gone trekking ;-)
As for sleep -it's highly overrated. ZZZZZZZZZ
Re: That sure do look like...
charlie belden
>Ellis:
Sometimes the Do Nothing Choice is the best solution. But like K.I.S.S. (keep it simple stupid), I tend not to take the obvious, and easiest solution, unless all else fails, or I run out of time - or money ; )
Nuts!? Hot Nuts!? Glowing Red Hot Nuts?!
charlie belden
>Andi:
I come up with some pretty Wild Hare Ideas, but it'd never occur to me to heat up a handful and a half of steel nuts to red hot - then dump them into a hollow form - cap the form - and shake and roll it around. THAT's crazy - wonderfully crazy!
Hmmmmm - wonder what would happen if you pour a molten tin/bismuth metal into a pierced piece - or maybe even submerge the piece then lift it out and let the liuid metal leak out through the piercings. Long tongs, fire suit, three folks at the ready with fire extinguishers - CO2 of course - breathing apparatus, shoulder length fire proof gloves, . . .
The electronics industry uses pools of molten solder and pass stuffed printer circuit boards over the surface to solder components to the board. Wonder what they use, its melting point and hazardous fumes issues. Hmmmm.
Thanks, I think, for yet another technique to look into.
Re: Nuts!? Hot Nuts!? Glowing Red Hot Nuts?!
AndiWolfe
>Ahhh, I see you found my article on playing with fire.
Yes, that's a great technique and it works fantastically well for texturing the inside of a vessel. Precautions must be taken, though, to not inhale the metal fumes. You also have to watch out for the hot metal.
