REAL MILK PAINT
which vicmarc
which vicmarc
which vicmarc
clay rose
>im seriously thinking about purchasing a vicmarc vl 300 long bed.. Whats the difference between the american and aussie version? anything? which is better. I'd like to know so I can evaluate my decision... thanks clay
Re: which vicmarc
Re: which vicmarc
Fog Tanner
>The short answer is the Aussie version is the better one. I have the real Vicmarc VL300 long bed made entirly in Austrlaia. I have also used the Craft Supply version and don't really care for it that much.
The Aussie version has a number of differnces. The base it much easier to work around than the CS version. I hate the splayed legs on the CS version I used. It was cumberson to work around the headstock, and they don't provide anymore support than the Vicmarc base. I like it enough than when I made a base for my mini, I copied the angles of the legs (5 degrees in the front and 15 in the back). The height came out to the same as my Vic,so the spread was within an 1". I also built a "chip chute" into my mini base after the one that is built into the Vicmarc. The CS version that I used did not have a chip chute. Its another one of those things you quickly get used to.
Mine has the controls in a fixed location, which I like better than the movable remote. All the switches in mine are G.E., so getting aprts locally isn't a problem should they get broken. The Aussie version has a red emergeny stop bar across the length of the base. It is the same as hitting the stop button, except you can do it from anyplace along the lathe. I have had to use it a couple of times when my hands were full (long story). I hate using a lathe without that now, and wish all lathes came with one. You really don't have a problem bumping it with your knee when turning, takes all of about 2 minutes to get used to.
I have a 2hp AC motor which I have never stalled, and I turn up to the max the lathe will swing. I also core the blanks which is a big load, but still no stalling. I have seen the CS version stalled several times due to the motor/controller they use. The controller in mine is a "vector" controller. It is much like having cruise control, it will maintain whatever you set as you put more load (i.e. cutting, coring etc). The Aussie version has a three step pully that allows you to set the range from slow to fast - lowest is 10-1000, highest is 30-3000. There is an led digital readout that gives you the rpm for the middle range.
The tool post on the Aussie version is 30mm (about 1 3/16") compared to the 1 in. on the CS version. I don't really worry about any flex on mine, but I have seen some 1" tool post flex and one that actually bent on a Oneway. The Aussie version also comes with a locking collar, which I doubt is on the CS version. It is a split collar that you can lock you Vicmarc chuck onto the shaft with. I have never had to use it on my chuck, but do use it with the Vicmarc balancing system I use.
If I had it to do over, I would get another lathe it would be the Aussie built Vicmarc - only sooner...:-)
Fog
Re: which vicmarc
Re: which vicmarc
RonZ
>I agree with Fog on the Aussie model. I have the new model which also includes adjustable height. Greaat feature for midgets like me.
As far as size is concernred, I like the short with a 1/2 extension.
Re: which vicmarc
Re: which vicmarc
wilbur
>What's the going price on the Aussie version of the Vicmarc VL-300?
Re: which vicmarc
Re: Vicmarc Prices
gtwilkins
>For comparison KMS Tools in Vancouver, BC has:
Longbed $4866.62 US$
Shortbed $4424.12 US$
Good if you are in Washington but I don't know what shipping would be!
Trevor
Re: which vicmarc
Re: Vicmarc Prices
Ralph
>In addition I suspect there would be a customs charge (since the Vicmarc in not made in Canada)...
One advantage of a OneWay
Re: which vicmarc
Re: which vicmarc
Joe Flemig
>Clay,
What you refer to as the US version, is not exactly that. You can buy the fully Vicmarc manufactured lathe in the US, or you can buy the hybrid version from Craft Supplies. Craft Supplies provides a value to the market by bringing in the machine without the electronics, motor or base, then adding those from local sources. This helps keep the cost down by only having to pay for shipping of the unique part (the lathe assembly itself.
Aside from that, the ergonomics are the difference as other have pointed out. I have used both and find both nice to use. One drawback of the "Australian" version is that the emergency off kickbar running across the front of the lathe is very easy to accidentally knee when turning - especially hollow forms and bowls.
Joe Fleming - San Diego
Re: which vicmarc
Re: Vicmarc Prices
Fog Tanner
>The Woodworker's Emporium in Las Vages has the Aussie version for around that price or less. It would depend on where you are at as to freight. I think their prices are fob Las Vegas. They are also where I bought my Vicmarc balancing system and some other Vic items.
When I bought mine, the VL300 longbed was $3000 fob Auissieland. It cost $1500 to have it shipped from Vic's factory. I bought it through a dealer in Texas at the time. The shipping from Australia to Las Angeles was $500, which was included in the $3500 I paid the dealer. The other $1000 was what it cost to have it shipped from L.A. to Houston.
Fog
Re: which vicmarc
Re: which vicmarc
Roy Girolami------WebKitFormBoundary9yANUT8mn8C+Zo
>One more thing to note. When I got my Vicmarc mini from Jacques Coulombe in Canada, the spindle thread was M33 x 3.5. I don't know if you can specify what you want if you get it through the factory, but don't assume it's 1 1/4 x 8.
Roy Girolami
Apex, NV
Re: which vicmarc
Re: which vicmarc
GLENN ROBERTS
>In Australia the VL300 would have a 30mm thread (for the Aussie market) so it would be worth checking.
