I have just spent the week with...
Jamie Donaldson
>...the best spindle turner on the planet, Jean Francois Escoulen from France. An amazing gentleman and turning artist, performing much of his work wielding a 1/2" bedan as a skilled surgeon wields a scalpel. He will be the artist in residence next week at AAW Symposium, and I encourage all to visit his demo area and watch a master at work. Here is an image of his work on display.
Re: I have just spent the week with...
Re:These are the multi- axis projects ...
Jamie Donaldson
>...I completed during the class, and his eccentric chucks are marvels of design which allow many whacky options for a variety of purposes!
Steven Antonucci
You were certainly busy!
steve antonucci
>And it looks like something may have even rubbed off on you, too!
Good stuff. How many did you break? ;-)
Steve
When did he add the "spears"?
charlie belden
>The "spears" appear to be something new.
When did he start using them?
I don't understand why the bedan isn't used here in the U.S., but I'm betting most here have at least one skew in their tool holder, and a few that actually use one regularly. Might be that we're just not comfortable with anything that doesn't have some sort of fingernail grind, or curve to the cutting edge. Yet, for spindle work, and of course some practice, you can do just about anything with a bedan that you can do with a spindle gouge - and many other things as well - like straight sided hollowing.
If you want to get a feel for working with a bedan, get a 1/4" bench chisel, chuck up a 1/2" to 1" dowel of poplar and start experimenting. With a sharp corner on each side, you can use either "point" to start a rolling cut and then make contact with the bevel to follow through. You can make nice shearing cuts down the blank for trembleurs and do all sort of things with it.
Multi-axis and eccentric turning, as you probably discovered, takes a bit of mental gymnastics to "see" where you're going as you turn mainly through air in the "shadows".
Could you fill in some details on his chcuk and what your experience with it was?
Mike Stafford
Mike Stafford
>Mr. D, did you use a bedan as well? Will we now be seeing multi-axis square work coming from the Donaldson studio?
Nice work, Jamie. I am glad you had fun. You sound enthused and that is always a good thing.
Steve Kubien
Steve Kubien
>Jamie, your enthusiasm is infectious. Makes me want to go into the shop and start playing with multi-axis stuff again. I've played around enough to know that I want to explore it further as time (-sigh-) permits. Sounds like a great time. Glad you had fun.
Steve Kubien
Re:Mike- I attempted using the bedan......
Jamie Donaldson
>...as does JFE, but then quietly retired it to the tool collection drawer beside the skews! The Thompson detail gouge is perfect for this application, and JFE showed me a better way to hand hone a tiny bevel that is a real cutting improvement over the previous jig ground edge I had been using.
Pascal Oudet
>you certainly were busy. glad you enjoyed it
Jamie -- please share this technique with us.....
GaryG in MD
>Sounds like something we all need to know... ...Gary
RonZ
>I'm glad you enjoyed him and I hope others will, too. I was fortunate to see him at Eli Avisera's Wood Craft Center in Israel.
