Seeing Very Subtle Curves In Shiny Objects
Brad Vietje
>Hi All,
I wasn't quick enough to respond to John's post about seeing very slight curves in turned work after finishing, so I'll start a new thread. At last -- something I have some expertise in!
I've spent many years making reflector telescopes, and teaching the sport to others. This involves grinding very subtle and very precise curves in glass or ceramic discs, and evaluating the curves with light reflections. Techie stuff aside, this involves lots and lots of measuring extremely subtle curves in shiny objects -- where a telescope's objective mirror has a lot in common with a gloss finish on wood. Its purely coincidental that John was talking about mirrors -- the turning could be bowls or buttons just as well.
With a little practice, we can learn a lot about a surface by bouncing light off it. Curves in the reflection, as well as thickness of reflected lines, and light and dark areas in the reflection of a uniformly shaded object (or of reflected light itself) can reveal features too small to be seen or felt otherwise. Simple optical tests can reveal flaws of a few millionths of an inch, a few nanometers, or a few dozen Angstroms.
In the mirror photo John posted, there appears to be a slight dip at the center, but a little more going on there. It looks to me like there are two small darker areas, so probably two small dips, or even a slight depressed ring, like a moat, surrounding a central hill. I'd have to tip the piece and watch how the reflection moved about, or know better where the light was coming from to tell for sure. In this sort of photo, a flat surface would be evenly shiny all over if the tilt was correct. That means that a wider reflection is flatter, while a narrow band of light is more curved. Thus, a relatively flat round area at center, and if you want to chase down really subtle details, you can look at the width of the reflection from center to edge to see any other curves.
Part of the problem is good lighting. Most turners strive for bright, even shop lighting so they can really see what they're doing. That's usually a good thing, but sometimes really lousy, uni-directional light is more useful for seeing subtle curves. For anyone trying to achieve subtle, even curves, you might consider turning off all lights except a single, un-frosted bulb, and moving it about so you can see subtle curves and scratches that would otherwise escape detection -- until the gloss finish is applied. The lower the angle of the illumination, the larger the flaws or ripples appear, like shadows at sunrise or sunset. The sharper the transition from light to dark, the larger the surface feature.
I'll post two ideas for seeing these issues more easily in a moment.
Safe spinning,
Brad Vietje
Newbury, VT
