Have a question? Ask Woody!
Help needed on first natural edge bowl.
GalenV in Iowa
>I was given a piece of walnut that I was told would make a nice natural edge bowl. OK so I have never done that!
Are the majority of natural edge bowls that are turned from green wood turned to the final shape and then left to dry to be able to hand sand and finish?
Are they ever turned to rough shape and dried and then turned to final shape and finished? Is there a greater chance to lose the bark and also be warped to far out to turn again?
Turning the foot will be a new one for me too as I have used jumbo jaws on a regular bowls.
John Lucas posted a great natural edge walnut bowl on June 1st that he noted was 1/2" thick. That is what I would like to try, not any thinner. If I could get half as good as his I will be happy for first time.
Any last wood would be of GREAT value.
Thanks
Galen
Re: Help needed on first natural edge bowl.
>Galen I try to turn natural edge bowls to completion because they appear oval anyway so any warping that takes place after turning will only accentuate the look.
I don't remember if I've ever twice turned a natural edge piece so I can't answer your question about bark.
If I have time I sand while it's still on the lathe. I use a hair dryer to dry just the surface so that I can sand without clogging the paper. If I want to sand green without the hair dryer I use the screen type sandpaper. I'm having a senior moment and can't remember the brand. I get it from Thesandingglove.com For courser sanding you can just drywall sanding screens but the finest they have is about 120grit.
I normally turn the outside of a bowl from the foot to the lip but on natural edge bowls you can pull out the bark so I turn the bark sections from the lip down.
The cambium layer and bark warp differently than the sapwood so if you want a perfectly finished edge you will have to wait until the bowl drys to sand it. In those cases I use my vacuum chuck to hold the bowl and sand with the lathe off. I lock my spindle on the powermatic using a wedge between the handwheel and motor and then power sand with my hand drill.
mike Nelson
>Galen, I have a technic for turning natural edge pieces, first spay or soak the bark with lacquer, I really saturate and let it dry. This is great for Mesquite. Walnut has a big tendancy to crack, green or otherwise. I usualy let it dry roughed out but still soak the bark.
Thanks John.
GalenV in Iowa
>Thanks John for your comments.
I have not tried sanding green by surface drying nor the open screen paper. Always willing to try new things. I can see why so many turners are making up their own vacuum chucks. Tried jamb chucks with tail stock support but never get it perfectly centered and somtimes things slip. At least the slipage would be reduced and let you finish off the entire bottom by turning.
Never thought about the shrink rate of different layers on wood!
Thanks again.
Galen correction: last "word" not "wood" :>(
Jim Sample------WebKitFormBoundary4+bM8dU5Q5ZoYOET
>Galen V
You are in Iowa, how far from the Council Bluffs area. Go to the Loess Hills Woodturners web site and look p the Bill Grumbine Demo on July 18-20. This would be a great learning experiance for you, I spent 2 days with Bill several years ago at LaCrosse Wisconsin. He is one of the best teachers that I have seen. It would be worth every dime of the cost. I will be there the 18-19. I live about 150 miles away.
Jim SAmple
AAW#26981
GalenV in Iowa
>Mike
If you turn rough and then return dry do you just go by experinces with the wood to leave enough wood to return if it moves way out of shape drying?
Stabilizing the bark sounds like a good practice. I know I have read where some even use CA glue along the bark lines.
Thanks for your comments
Galen
GalenV in Iowa
>Thanks Jim
Turners from Loess Hills Woodturners were at one of our Ames turners meetings and invited us to attend some of the seminars based on a need to help meet a minumum attendance. I imagine that one will be filled!
Going to Albuquerque AWW Symposium since my sister lives there. Right now hard for me to determine what demonstrations to attend. They will probably not let me in to Bonnie Klein's youth classes!!!
Galen
Chip in Plano
>I first start with a forstner bit drilling a hole through the bark and soft cambium layer into solid wood. Hit it with some CA to strengthen it. Then use a spur drive well seated....between centers with the tailstock to turn it. It takes a couple of tries to get it balanced, too.
Once I get the basic outside profile, I will start saturating all the bark arond the edge with special concentration where it meets the wood. Traditionally, I use thin CA with accelerator (b/c I'm impatient) and thick CA (or Inlace) for any voids. Then I will go for the final outside profile with some confidence that the bark will stay on. I almost always turn backwards/downhill than the normal tailstock to headstock direction for the outside of a bowl....until I'm into solid wood. Then I go back to the normal approach to complete the shape.
By then, I've probably turned a lot of the CA off so I'll hit it again. Turning the bowl around to core it, the process is similar. As I approach the final inside cut, I'll hit the bark with CA so I don't tear it off. The key with the NE edge is watching the ghost edge and taking light cuts. Once I start a cut, I commit to the cut all the way to solid wood.
The biggest mistake I make with NE bowls is the profile. I tend to make steeper sides than I like. So think about if you want a wide open bowl or one where the edges wrap up and gently back into the form.
Last comment....Where dust and face protection. Bark can come off in big chunks that sting. And breathing the dust and mold is really bad on your lungs. I actually wear a leather apron, too, which sucks in the heat of a Texas garage.
GalenV in Iowa
>Thanks Chip
You supported what I was told on using a forstner bit rather than trying to chisel in the thick walnut bark. Need to do that more often than my chisel ability.
I found just doing pens and stopers of walnut I needed a mask as the dust of walnut gives me more problems.
I "plan" on a more open bowl with the thick bark of walnut especially if I leave it 1/2" thick.
Glad my turning is done in a cooler basement except sometimes I feel like a mole! A hot garage would slow me down some.
Better get busy now and turn.
Galen
Dennis in Southern Oregon
>Galen, I move for completing the turning and sanding wet. Instead of trying to dry the surface to prevent sandpaper clogging, I use water as a lubricant. If you keep the sandpaper dripping wet by dipping it into a bowl of water frequently, it will not clog badly. I find that wet sanding to a fine grit produces a better finish than sanding after drying. Be sure to wipe the slurry off between grits. Dennis
Chip in Plano
>Good comment especially on really porous woods. Sometimes, I will skip a step and do the sanding with tung-based oil.
I guess it's time to put all this into a NE bowl sitting on my lathe.
