New mirrors
New mirrors
New mirrors
>I'm trying to get an order for a dozen mirrors out the door. I only need one more. These are in the finishing stages. The platter was something I was just playing with. The carving for the dressing table is on the left. I've filled in the missing parts and now I just need to carve the parts and put some finish on.
Re: New mirrors
Re: New mirrors
GalenV in Iowa
>John
Very nice!
My first thought about the one to the left of the platter is it looked so much like polished rusty quartz not wood.
Are the two bloodwood made with veneer inlay or segmented?
I saved an article you wrote some time back on turning your mirrors so still one item I would like to try. Not sure I am ready yet for seven years bad luck with a broken mirror.
Galen
Re: New mirrors
Re: New mirrors
Dennis Taylor
>John,
those are great mirrors, and I have asked before, but do you have a copy of your how to article or do you have a site with info on making the hand mirrors?....You sent me something before, and I sure can't locate it now, I have some 5" mirrors, and ready, if yo have the info yet?...tks...Dennis
Re: New mirrors
Steven Antonucci
I like the green one.
steve antonucci
Re: New mirrors
Re: New mirrors
Marc Phillips
>Very nice! ... I see you deviated from your usual graceful handle style on the one in the middle... looks very comfortable to hold!
Re: New mirrors
Re: New mirrors
>The one to the left of the platter is a very nice piece of cherry moulding. The place where I buy my wood had cut that end off the moulding because the customer didn't want all that "ugly" curl and crotch design. I got 4 feet of it.
The circular inlay is a segemented ring. I make these 3/4" thick and then glue them to scrap, true them up face off one side and then use a custom made scraper that has the same 10 degree angle ground on each side with the end being flat, to true up the sides so they have a 10 degree slant to both the inside and outside of the ring. I use this same scraper to cut the groove in the mirror blank. The taper allows me to check both the inside and outside for perfect fit. I find it easier than trying to make 90 degree that perfectly fit the ring. While it's still glued to the scrap I take a thin parting tool and cut 3 rings about 1/4" thick. That way I can make 3 mirrors out of 1 ring glue up.
With this method I use the parting tool to cut the groove to the narrow width of the ring. Then I use the custom scraper to angle the sides. I put the ring in and see how it fits. It won't usually sit down very far. If it touches the inside but the outside has a gap, I take a little more off the inside. Then the outside will touch and the inside has a gap. I take some off the outside. A few trial like this and the ring will drop down to the perfect depth. I don't need it to sit perfectly flat because I will fill the space with epoxy. I drill holes in the bottom of the groove so the epoxy has somewhere to go when I insert the ring. If you don't you will break the ring when you apply pressure (guess how I figured that one out)
Re: New mirrors
Re: New mirrors
>Dennis I don't have it on the computer but can make you hard copy and mail it. Send me an e-mail with your snail mail address and I'll get it in the mail.
Re: New mirrors
Re: I like the green one.
>Steve that one was a new concept and I don't like it. I like the idea but I'm not a good chip carver so the leaves are kind of rough. The long spiral is what I don't like. It's just not true enough or clean enough. I've got to work on my carving technique. I also need to do a better job on the airbrushing. It was fun and I'll try it again. The overall concept is nice I just need to work on the design of the piece and the skills a little more. It will sell I'm sure because it has that hand made country charm.
Re: New mirrors
Re: New mirrors
>I do this style handle often when I have 1" handle blanks. Usually my handles are 3/4" thick and they just don't look as good with this style handle. The one on the right is an example of that. They are OK but the thicker handle just appears more balanced. I make that style handle using the Knurling cutter from my metal lathe. It leaves an industrial look and sells well to men.
Re: New mirrors
Excellent as always !
Don Orr
Re: New mirrors
Re: New mirrors
Bill Crommett
>I like the platter.
Re: New mirrors
Re: New mirrors
mike Nelson
>The one in the middle by the big one!
