ADVERTISE HERE - FREE TRIAL
OT- Computer Guru Help
Tom Minehan
>I have an older Dell computer running XP. I now find I cannot write to my cd drive although the drive will read a CD. I've spent too much time trying to figure this out including wandering around the Dell "Help and Solutions" web site without any help. I can buy an external CD/DVD drive with more features than I will ever use for less money than taking my computer for repair. Do these external drives work independently from the drivers installed for the internal drive? (I can write to my floppy drive and external hard drive.)
Re: OT- Computer Guru Help
Colin
>Yes they do work independently so no problems there. The drive is probably past its sell-by date. It is cheaper to buy a new internal drive than an external one. They are usually retained by 4 screws and have 3 cables in the rear one for sound, power and the last for the data. If you do decide to go for the internal replacement then you will probably need an ide drive, the later Sata ones probably won't fit. Just look at the cable connectors if one is an oblong about 2" long it is ide and if they are smaller and generally black then it is SATA. One of your neighbours kids could change it for you in about 10 minutes if you don't feel confident. ;)
mark wollschlager
>When you say you can't write to a cd, do you get an error message?
Are you using the Roxio or Sonic software that came with the computer?
Are the writable disks brand name or generic?
It could be that the directcd driver is disabled.
I have also found that some cheap, generic CD-R's are borderline in quality.
Some of our systems ( all Dell ) will not write to them, sometimes rebooting the computer during the cd creation process.
Buying a new cd writer may cure the problem.
They are not all that expensive, be sure that the cabling of a new cd drive matches your current setup.
The older style connectors will be ide/ATA and the newer ones are SATA.
Your system may have an extra SATA connector, even if the current CD drive is ide/ATA, then you will just need a new cable and power connector
( these are sometimes packaged with the drive, check the box ).
hope this helps.
Mark.
D. Hansen
>Memorex used to make a super internal Cd that will write to both sides of the disk.Of course the two sided disk are a bit pricey. The software with the Memorex is superb and as stated above a snap to install. Go for a new drive and get your problems behind you. No use messing with old drives anyway. Its like working with unusable wood to make a bowl. Not worth the time.
Tom Minehan
>The problem started when I tried to copy some pictures to a CD. When I tried to save them they would not go to my CD drive(E). I would get a message saying something like "Files waiting to be installed". Trying to install them brought a message that said something like cannot save because "source and target " folder are the same. When I tried to save a "Word" file I would get a different message that said something like "access denied see your administrator". I spent a lot of time trying to figure out what is going on but not being a"nuts and bolts" computer guy I am lost. Part of me says it's a software problem and part of me says it's a hardware problem.
During the period I was sorting things out I would get various error messages. Currently for Word files I get a message that says "You do not have access to this folder - see administrator" after hitting enter the message is "the parameter is incorrect". For picture files I still get the "files waiting download message" but even though the drive runs the files do not transfer. I should add that the drive doesn't seem to run when attempting to transfer "Word" files.
This is the first time I have had trouble copying stuff to the CD drive. As I previously stated I'm not a real computer person and do not know if I have a software or hardware problem. My real question is can I spend 50 bucks on an external drive and in all likely hood be done with it?
Ken Oakley-Sunny St. Cloud, Fla.
>I have a 4 year old Dell Dimension that has had the CD/DVD drive replaced twice and needs a new one again. The last tech who changed out the drive said it is very common to the Dells. It took him about 3 minutes to remove the old and install the new. Both times were warranty claims so I have no idea the cost but hear thr drive is fairly inexpensive and I think I could change it out myself
USB Difficulties
Al Goldstein
>Tom,
I've had troubles with my Dell computer as well. Then a friend told me that older Dell computers don't have a strong enough power supply to support multiple USB devices. I find that my Dell won't recognize a jump drive if my printer (with a USB connection) is on. Once I turn off the printer (or an external hard drive) then the jump drive will be recognized. And I've had similar difficulties with other USB devices connected to this computer.
So I would suggest that you try again to write to your CD drive, but first turn off all other external devices connected via USB ports.
I hope this works for you. If not, then it is the CD drive at fault.
Good luck.
Al
steveotm
>Know this is an old thread,but my niece has an old Dell laptop and she had the same problem. It seems the drives are fussy about the brand of blank discs you use. Use a big name brand of disc and it will work if the drive is ok. She now has no problems...
