A loud bang and I was walking toward the light...
steve antonucci
>to shut the dang thing off!
I had decided to make a large natural edge cherry lamp shade. Third time I've tried, and I am 0 for 3. First one ended up as a small djembe. Second one is a large bowl that I am not very fond of.
This one started off pretty nicely, until I got a catch removing the center cone and blew up my natural edge whilst also slammin' up the back of my right hand. So, I went for a large translucent bowl. It was 1/8" all the way down, as measured by the 100w light bulb I was using to gauge wall thickness. One small nib at the bottom to get and I was done.
I had been working on it all day, and I suspect that I had remove 49.5 pounds from a 50# log. The lathe was running at 1000RPM and I was tired, so I didn't think to slow it down. One last cut...
What actually happened is still subject to debate. One second, there was a large translucent end grain cherry bowl in front of me, and the next minute, I was staring at a 100W light bulb. No hint of a bowl at all. Apparently 1/8" of wood isn't enough to hold a bowl if you get a minor catch when cleaning up the inside of the bowl with a scraper.
Will I try it again? Probably. Will I push 3/32" next time? Why not? If I'm going to die, I going to die trying...
steve
