delta saw
jimtex
>hi ya'll! recently i went to start my 14" delta band saw and it failed to operate. it will hum for a few seconds then trip the gfci. it is not bound up as the wheels turn freely. anybody got any ideas?? thanks, jim
delta saw
jimtex
Re: delta saw
JohnKyler
>Sounds like a starting capacitor.
I would guess you could give it a good spin with the switch on (before the GFI trips) and it likely will run?
John
Re: delta saw
Ken Oakley-Sunny St. Cloud, Fla.
>I put my money on Johns answer.
Centrifugal switch ?
Doc Green
>I have a Sears radial arm saw (1985 model)that periodically shows the same symptoms: hum but not start. The problem is dirty contacts in the centrifugal switch. I take the switch apart, clean the contacts, and I'm back in business.
I'm not familiar with the Delta bandsaw. It may not even have a centrifugal switch. Do you hear a click as it slows to a stop? If you do, then it does have a switch. That's the first thing I would check. Good luck. ~Doc
Re: delta saw
Texian
>Could be both the switch and the capacitor. Had same problem with Delta table saw.
gerbil
Steve Kubien
>You need a new gerbil.
Steve
-sorry, suffering with a fever and possibly over-medicated
Re: delta saw
Dennis in Southern Oregon
>John, did you mean the circuit breaker or the GFI breaker? The GFI breaker should not trip unless there leakage current to the ground return. If that is the case, you need to isolate and fix that problem.
Dennis
