Photo ppi?
Paul Zerjay
>Can someone please tell me how to re-size my photos to 300 ppi? I'm late on a show entry and I need to write a cd. I am by no means a photo wizz and only have irfanview and picasa. Thanks
Photo ppi?
Paul Zerjay
Re: Photo ppi?
Brad Vietje
>Paul,
You'll get better advice than mine, but since you're in a hurry, I'll offer what I know:
If you have Windows XP, you could open an image in Microsoft Photo Editor, select Image, then Re-Size and use Save As to make a copy and avoid screwing with the original.
There's also a free program called Pix Resizer, and a fancier one called Shrink Pic that you can search for and download for free,
I use MS Photo Editor, which is very basic, and very easy.
Good luck!
Brad Vietje
Newbury, VT
Re: Photo ppi?
Bruce McElhaney, Spring Lake, Michigan
>Resizing photos is pretty easy with Photoshop or Elements. Both are great programs and worth the investment. While I'm not familiar with Irfanview, I found some info on their website. Looks easy enough. Go to their website and click on FAQ. Look for a thread on resizing photos. Then just follow the instructions.
I'm sorry I misspoke
Paul Zerjay
>I need to change the resolution to 300 PPI and not re-size the photo
Re:I was just about to ask......
Jamie Donaldson
>....about the 300ppi resolution, as that is the standard for images that are going to print output, just as web use only requires 72 ppi. If the dimension is a size requirement that's a whole nother ballgame, such as ZAPP using 1920x1920 pixels for the size of the image that is to be used for projection.
Re: I'm sorry I misspoke
Alex Yeilding
>I'm not sure you can. I think the DPI (or PPI) is a setting when you print. E.g., if you have a picture that is 800x1200 and print at 300 DPI, you will get a 2 2/3" x 4" image.
Resize/resample is a menu choice under "image" in irfanview.
When I print, the popup screen has a "printer setup" choice, and from that popup, "properties" lets you make another choice, which is printer-dependent. Maybe "Normal", "Draft" or "photo quality", or some other setting that translates to DPI.
Then again, maybe I'm all washed up here -- not my area of expertise. But when did that ever stop anyone on the net from offering advice? ;-)
Re: Photo ppi? *LINK*
Fred Holder
>Photo Shop Elements allows you to change the resolution (dpi or ppi). I do it all of the time. My camera takes the pictures at something like 260 dpi and I change them to 300 dpi for printing my magazine with Photo Shop Elements.
More Woodturning Website
You can but will it be right?
Ron in Drums PA
>Downsizing will work fine, but if you want to increase a 72 PPI image to a 300 PPI it not will be suitable for printing.
Imaging taking a photocopy and enlarge it by 400%. Can you say jaggies?
email me the image and I'll change the ppi for you.
Re: Photo ppi?
Ed in Leaside
>Did they specify an exact image size such as : 4x5@300dpi? Unless you know the final print size you cannot reduce to an exact ppi. ;) Seeing as you're sending a CD you might as well send what you have. Whomever is on the receiving end shouldn't have any problems with using it, unless it's already under pixeled, in which case you'd have to retake the picture.
Ed, in print since '75, would rather have too many pixels than not enough.
Re: You can but will it be right?
Paul Zerjay
>Are you sure you want to do that? There is more than one image.
It seems PPI has nothing to do with image size---- *LINK*
jerhall------WebKitFormBoundaryS55vZAaXJsx+Qg1Q
>or pixels. If the printer prints at 300dpi (pixels per inch) the picture will be smaller for a smaller jpeg pixel count, and larger for more pixels. At least that is the point made in this Picasa help forum. So I guess you need to know the print size desired at 300 dpi and work back to pixel count. Of course your original jpeg file has to be high enough resolution to work down to your objective. You can't go up.
PPI Revealed
Re: Photo ppi?
>I want to help, but I'm a bit confused about your image needs. FWIW, Changing PPI falls under the domain of, Resizing and you would need to open that dialog box or window in most imaging programs. BTW, I've never heard of a show that wanted 300 dpi image resolution. As previously mentioned, 300 dpi is printer resolution, and suitable for print output or hard copies, and not for Zapp or image-ready service. Most jury services, like Zapp, require 72 PPI resolution at 1920 x 1920, max. pixels.
If you ARE looking for print output resolution of 300 dpi to make a print, and your image's current res is lower, you usually cannot increase image resolution without losing image quality unless using a program like, Genuine Fractals or such.
