Second and third pens
wilbur
>For Jim, who said about my first pen, "So when will we see more??"
Here are #2 and #3. All I needed was a skew chisel and sandpaper. They are for my older boy's kindergarten teacher and the kindergarten teacher's aide. He graduates from kindergarten tomorrow, which I guess means that he learned how to take a nap and stand in line. :@)
One thing I learned about using spalted maple: it really sucks when you turn down what looks like a nicely spalted pen blank only to find out that when you're at the final diameter all the spalting is turned away, and you're left with just slightly discolored maple.
Re: Second and third pens
Steve Kubien
Steve Kubien
>Looking good Wilbur. I know what you men about spalted woods. I was working on a couple of Sierra's last night in between cups of Neo Citran. Looked good as square blanks. One step above bland by the time I was done. I still don't know whether I will actually assemble them.
take care,
Steve
Extra Tubes
Jim Shaver - Oakville, Ont, Canada
>You are a quick study Wilbur,
I mean that, you are skilled in so many ways, I see you post on all three boards here and I know you have a keen passion for what you do in the shop. These pens are in keeping with that core of your passion for learning and wood, I think they are indeed great!
Your thoughts on spalted woods is one I have found with a variety of materials used for pens, with such a small amount of surface to display the beauty of what you are working I too have seen the anticipated surface end up in turning shavings left with the more mundane base to be the finished surface. Years ago I started buying extra tubes and turning those in batches of 10-20. Then selecting the best ones for my craft sales and the balance going to donation gifts etc at school. I also found I went looking for materials that packed a ton of figure in a small space, as Chico calls it, Wood that makes your eyes go Buggy! I went to burls almost exclusively then. I also switched from natural woods to stabilized woods, easier to finish in my mind, I use the same process on them as I do on acrylics. One process, and simple, makes my turning in batches easier.
Again Wilbur, you are on your way and already learning what you like and don't like...so far you are A+ my friend!
take care,
Jim
Jonathan
>They do look great! About the maple...that result is better than turning the wood down to the bushings only to find a knot or something in the wrong place that messes up the whole thing. :-)
Reading the spalting on pen blanks
wilbur
>Thanks for the kind comments!
One thing I noticed regarding the "spalting on the outside/plain maple filling on the inside" issue -- it looks like you might be able to predict how the inside will look by examining the end grain of the pen blank.
If the spalt line crosses the blank on the end grain across the middle of the blank, the spalting will likely carry down to the final diameter.
If the spalting just clips the corner of the blank on the end grain, however, there seems to be a fair chance that it will be lost as you turn it down.
I could be wrong, though.
Re: Reading the spalting on pen blanks
Gary Evans Tallassee, TN
>You are correct to an extent, Wilbur. Sometimes the line that you see on the end of the blank will extend all the way through, sometimes it won't. Sometimes you won't see any spalt lines on the end or the outside, but there will be spalting on the inside of the blank.
I think you just have to expect some loss of blanks when you buy a bunch. I imagine if you really needed to you could recycle the tubes.
Are those some of the blanks you got from me? Nice pens, by the way.
Gary
wilbur
>Hi Gary,
The spalted maple blanks are the ones I got from you. Thanks!
