>I've been using Liberon's Woodturner's Lathe polish followed by a wax stick, and I'm coming to the end of my bottle. I thought I'd try something else, and was looking at the Mylands products. OF course, I came away confused after looking though their product line.
Can someone clarify the difference between a sanding sealer and a friction polish, and do you need both?
It seems that the sanding sealer is lacquer based. So why couldn't you use it as a finish itself? Or use shellac instead?
I believe the sanding sealer is just what it says it is, a sealer to be used under other finishes. Yes, you can use plain shellac as a sealer or a lacquer sealer under lacquer coatings. The friction polish is shellac plus a wax emulsion which will give a higher gloss finish than just plain shellac. The nice thing about the polish is that when you apply it and run the lathe for a bit you are done. I use it for small items like bottle stoppers and small boxes.
>Wilbur, I don't turn many pens, so you take this for what it's worth. I stoped useing friction finishes. One of the members of my club got me started useing CA glue as a finish. Only on wood pens though. I build up 6-8 coats of CA and then sand it down to a smooth finish. Then Buff the blank with the Beall system, only useing the red and white compounds. Then I put a coat of Renaissance wax on anf give that a good buffing.
I am sure everyone does it different, but that's my way and I am sticking to it.
Your pens are looking great. Keep up the good work.
>In its simplest terms- sanding sealer is a grain filler used in preparation of the wood surface before applyhing a finish, and a friction polish is a finish to be used after the surface has been prepared.
A commercial Sanding Sealer is either lacquer or shellac that has a filler and lubricant material added to it to fill the grain and keep the sanding dust from clogging up the sandpaper after it is dry. That something extra is usually a stearate, but you can make your own by adding some talcum powder or wood flour to either lacquer or shellac.
A Friction Polish is either lacquer or shellac with an oil, usually Boiled Linseed Oil, and sometimes wax added to it to lubricate the polishing of the finish as it dries from the frictional heat of the applicator rubbing on the wood.
You can use a friction polish as a sealer by sanding the surface after it is dry, but there is no way you can use a sanding sealer as a friction polish unless you add the oil to it.
