Recent work
>I just finished this lidded box today. The box itself is spalted hackberry that Stuart Johnson sent me. The top is Gaboon ebony, and the finial is fossil ivory.
Comments welcome.
Ellis Walentine, Host
Recent work
Comments welcome.
Re: Hah! The only thing I can find ......
Jamie Donaldson
>... fault with are the wrinkles in the backdrop!! Good stuff Ellis!!
Thanks, and here I thought...
>... those wrinkles were pretty cool. Oh well. I haven't been able to use my seamless since I bolted my miter saw to the table under it. I keep thinking I will get a piece of gray Formica or a window shade and just hinge it from the ceiling somewhere to use as a mini photo studio.
Then there's the light dispersal issue. I like your phrugal studio method -- and it is a great innovation -- but I also like the idea of a translucent box with lights outside it, whatever that's called. I think you might have more control over the lighting and highlights and such with that kind of light-box setup.
Since good photography seems to be a recurring theme around here, I'm wondering what the next step up from the bare-bones approach might be?
You turn? ;-)
steve antonucci
>I thought you just ran the joint?
Howw does fossil ivory turn? I've seen it for knife scales, but I thought it would be brittle to turn? Sharp tools, light cuts?
Like your signature shape, too. Tried it in a hollowform a few weeks back and ended up with a nice bowl...
Steve
Fossil ivory
>It turns like dried-out ivory, and yes it is rather brittle. This finial has a .230" tenon. My first finial had a .188" tenon but it broke off.
In the old days, before it was politically incorrect, I used quite a bit of ivory in my work. The last of my inventory went up with the shop in '99 and I haven't looked back.
Re: Recent work
WayneLeach - NW Ont
>Wow, that's some serious spaltig going on.
I like the shape, it reminds me of some of the old things at the cottage when I was a kid that my dad burnt when he went on a cleanup campaign.
The form and lid look very nice and also functional,good job.
Wayne
Very nice work, and well done curves...
Gil Jones...GA
Hmm. Hollowform to bowl...
>...that's an interesting development. What happened?
Re: Thanks, and here I thought...
>Ellis Hanging a backdrop and finding space is one of the hardest parts of photography. My table saw becomes my home booth. I have 2 poles imbedded in gallon cans filled with concrete. I put a piece of PVC between these to hold the backdrop. The pole/cans are useful around the shop for all sorts of things and don't take up much space. You could easily attach a pull down shade to it. formica can be hard to use because it's pretty stiff and quite reflective. I use a lot for jewelry and glass but seldom use it for other work. For what we are doing wrinkled cloth works quite fine although it does tend to pull your eye away from the work. However this isn't a juried competition and we have more than 15 to 30 seconds to look at the image which make it easier to ignore the fabric.
I call the translucent panels a photo booth. I've tried a lot of methods over the years of shooting craft work and find them to be the most versatile. You have more freedom to move the light outside the booth and you can put cardboard or screen anywhere outside the booth to control the light better.
I like your box a lot with one little exception. The top of the finial seems too blunt or ends to early for my taste. Of course I take some flak occasionally for having sharp ending finials.
Beautiful turning......... I like the wrinkles
Ruth Niles
>The wrinkles go with the spalting : )
I love the turning. You did really good!
Re: Recent work
Mike Stafford
>Great looking box, Boss, from a terrific piece of wood. I like the balance you achieved between the lid and bottom. The way the lid is a continuation of the curve of the top of the body of the box is very well done.
Fossil ivory is a material I have not turned but I have inlaid pieces of it decorated with scrimshaw done by a friend into some pieces of my work.
Nice box, Ellis.
Didn't know you spun...
Chip in Plano
>I like it. It a soft pleasing shape and the woods/ivory compliment each other well. I don't do enough taller box forms.
Caramba!
Jorge Castaneda~Downeast Maine
>El Jefe
hace muy buen trabajo,
me gusta...
Gracias, Jorge
Thanks, John
>Your portable studio arrangement sounds simple and effective. What would you use for translucent scrim material around the top and sides to create a photo booth? I may just play around with this and Jamie's reflector-card setup to see what works best for me.
The finial detail does look a little blunt, but I did it because this is a functional piece and a sharp point didn't seem to be finger-friendly enough.
Thank you for your comments and suggestions.
GLad you like it, Mike
>Coming from a master, a comment like that makes my day.
Cut through the side while undercutting
steve antonucci
>Guess I need one of them laser-ma-jiggies :-)
I was pushing the wall thickness for a 1/16" ( a real 1/16", not one of those fish story 1/16ths!) and I cut it clean in half. almost all of these can be salvaged into bowls pretty easily if you have good form. Sure makes getting the insides out a lot easier when your "entry hole" goes from 1/2" to 6"...
Steve
Re: Recent work
Bill Clark
>Great piece Ellis. The spalted hackberry is beautiful. I like the form and contrasting lid. Nice work!
Re:Ellis- in the past I have made ....
Jamie Donaldson
>..photo enclosures with translucent sides made of drafting mylar(Dad and Grandpa were architects), frosted shower curtains, white bed sheets, thin foam packing wrap, ripstop nylon, all kinds of stuff that allows light to pass with diffusion. John and I have many tricks from our bags of photo goodies acquired thru the years, and I find the foamcore enclosure to be less technically challanging, more efficient with minimal specialty lighting equipment, and easier for others to use. It doesn't require multiple light sources, thus creating multiple highlights and shadows, and gives the average shooter more control over a lighting process which they don't often fully understand.
nicely done!! thanks for sharing
Thad
Re: Recent work
Mike Rubes, Apex, NC
>Hi Ellis,
That's a very nice piece. I like the overall shape and form, but really love the choice of materials. I think the ivory and two wood types really compliment each other.
Thanks for the picture. Nice one of you with all the ivory as well!
Mike
Shop time is around the corner in Apex, NC
Re: Recent work
Stuart Johnson
>Very nice Ellis. It makes me wish I had been able to save all the wood. We had three trees removed and I was only able to store a few pieces. The good part is it all spalted just as nice.
Thanks, Stuart
>I have at least four blanks left from that care package. I can't wait to play with the rest of them. I had never turned hackberry before and I was pleasantly surprised. There is no punkiness in the spalted wood at all, it turns very nicely, and it sands to a high polish. Perfect stuff. Thanks so much for sending me those pieces to play with.
On another note, I just scored a truckload of mulberry. I'm planning to turn spaghetti bowls from at least half of the logs, but there could be blanks left over. If so, I'll be happy to ship some to anyone who wants to pay the freight and handling.
Re:Ellis- if there is much moisture .......
Jamie Donaldson
>....left in that spalted hackberry you should turn it or dry it ASAP. It goes from spalt to punk rather quickly,like a few weeks, much faster than woods like maple.
It seems to be pretty dry
>The first piece didn't distort at all after initial turning. What's left seems to be holding its own. I'll keep an eye on the punk.
