Help, newbie turning question.
Brian in Brighton
>Help. I started turning a small urn to hold me kitties ashes last night. I had some problems. The urn is about 3 inch dia x 3 inch high.
My experience is limited. I have a Delta variable speed floor stand lathe.
I got the side done fine between centers.
Took the part off the lathe and put on a face plate with double face carpet tape. Tried to turn the end of it and it came off about 12 times, no matter how slightly I touched the tool to the base. How do you hold it on with tape?
I put the part in the drill press and drill a 2.125 hole in it. Now I turned the face plate to make a jam chuck out of it. The same thing happened when I tried to turn the base. It held better, but not quite good enough.
Does anyone have a you tube video that they would recommend, or any articles that have pointers? I'm trying to get it done by the end of the week.
Thanks,
Brian in Brighton
