I'm having a brain fart....
Donna Banfield
>Yeah, I thought the subject line would get a few more looks...:^)
I'm trying to turn small beads/buttons. The wood is typically 3/4" by 3/4" square, and between 1/4" and 3/4" thick. The blanks have a hole drilled through already -- I got the idea by using the cut-offs from trimming the wood off pen blanks prior to using the barrel trimmer.
How I was holding the wood: waste blank of poplar, held in a chuck. On this I turned a narrow tenon the size of the hole. I wet the wood to create swelling, put the wood on the tenon, and brought the tailstock up against the end of the tenon. This traps/holds the button blank, because the tailstock point creates a 'flange'. I can then turn the button with a detail gouge or skew, and when I pull the tailstock away, I can remove the button.
This worked fine for wood that was 1/4" thick, but the thicker wood stuck on the tenon, or broke, leaving the remains of the tenon jammed in the hole.
I know that I've seen homemade jigs, that allow you to turn thicker blanks of wood. Something that would expand when I bring the tailstock up and use it to create the flange, but would be stronger than the wood tenon that I'm using.
So this is my brain fart -- I don't know what it's called, (almost like a reverse collet chuck?) so a search in the archives gives me everything I'm NOT looking for.
Anyone have any ideas? Can you help me out?
Re: I'm having a brain fart....
Steve Kubien
Sorry, my brain has gas too.
Steve Kubien
>How about cutting a thin kerf along the length of the tenon. When the point of the tailstock is brought up, it would force the tenon apart and it would act like a 4-jaw chuck in expansion mode. If you under-sized the tenon for a loose fit, when you withdrew the tailstock the bead would slip right off.
Or am I no where near what you are talking about?
Steve
Pin Chuck?
Tommy Holmes
Expanding Collet Chuck...
Peter Teubel
Re: Sorry, my brain has gas too.
Donna Banfield
>Steve, that's pretty close to what would do it.
What to use for a tenon, though is still up in the air. If wood, it has to be strong enough to be able to turn a very thin tenon, but then still be able to cut a thin kerf with a blade, I'm thinking a dremel type cut-off blade?
Re: Pin Chuck?
Donna Banfield
>Tommy, I have one of those, but I've never found it to hold very well.
However, it was trying to hold a bottlestopper blank, and what I'm trying right now isn't nearly as big. Maybe I'll give it a go tomorrow -- if I can find it!
Re: Expanding Collet Chuck...
Donna Banfield
>Right now I'm trying to use what I've got available to me; I don't know if what I'm working on is going to end up as a finished product. I don't have a collet chuck, and don't want to buy one if this idea doesn't pan out.
Gas-X for the brain...
Peter Teubel
>Same idea, but have a split-tenon chuck machined from steel by GreenCo. It's last longer than a wood one and Mike would probably like the project.
since you using
Ian
>cutoffs from pen blanks why not use your pen mandrel. you can use a couple of bushings or pen tubes to hold the piece in place. and lock it in with the mandrel nut.
IAN
Screw Chuck !
Doc Green
>Donna, I just finished turning a "button" from endgrain walnut that is 1" in diameter and 1/4" thick at the center using a screw chuck (center-screw faceplate). Center hole is right at 1/8".
The screw I used is a 10-24 machine screw mounted on a backing plate of sorts held by a scroll chuck. A Dremel disk grinder was used to cut a single, thin notch partway down the side of the screw to make it self tapping.
Endgrain wood doesn't hold threads well, so I wicked just a tad of thin CA into the hole before I threaded it onto the chuck. With sidegrain wood, you can skip the CA.
Worked like a charm! I trued the very irregular blank and then made several finishing cuts across the face to bevel the button. Then reversed it, and did the other side.
You didn't give the size of the hole in the center of your blanks. If it is perhaps 7 mm, a 5/16" thread might work. And thicker blanks would be even better. Good luck. ~Doc
>Assuming you have a jacobs chuck or can chuck a small bolt in your regular chuck.....
Could you tread the pieces onto a bolt that would fit through the hole and tighten a nut against them to hold them in place and then chuck the bolt into the chuck on the lathe. You could use scrap wood to give you room to work between the nut and the head of the bolt or you could use lock washers.
I have also made pin chucks by grinding a flat on the side of a bolt and inserting a finishing nail into the slot. Then twist the blank to seat it. I have also use a little tape in there to take up any slack.
Re: since you using
Donna Banfield
>Ian, that would give me the ability to turn to top/edge, but the bushings would get in the way of finishing the face on each side.
By the way, what happened to you at the New England Turning Symposium? You were registered, but you never picked up your registration stuff?
Re: Screw Chuck !
Donna Banfield
>Hi Doc, that sounds like it would work very well, and last a lot longer than a wood tenon. I'll have to go about making one, or maybe talk to the owner of Greenco, Inc., a friend with a metal lathe who loves to make all kinds of this stuff.
Steven Antonucci
Only made a few...
steve antonucci
>For buttons, I just use double sided tape on a wooden mandrel.
for beads, I would continue doing what you are doing, but if the bead won't come off easily, I would part it from the mandrel and drill out the middle with a smaller bit.
if you want to make an expanding mandrel, cut your "peg" round and drill a smaller hole in the center. use a razor saw to create 2 slots in the peg, and insert a small pin in the end to make the peg expand slightly.
Steve
Re: since you using
Ian
>hi donna,
we had a death in the family that week and all plans had to be changed. it was disapointing for me to miss the symposium. but i felt even worse for my daughter in law, I had invited and paid for her to go as well. it would have been her first symposium. oh well, theres always next time, and hartford next year.
IAN
Re: since you using
Donna Banfield
>Ian, I'm so sorry to hear of your loss. You have my sympathies.
I missed seeing you at Pinkerton. I appreciated our talk about my demo at the Yankee Symposium; I made sure to focus on those things this time, and I had some very positive comments. Thank you.
Looking forward to seeing you in Hartford next year. I will be attending my first national symposium and I'm so excited!
