ADVERTISE HERE - FREE TRIAL
First pen -- thanks for the advice
wilbur
>About a week and a half ago I posted a question as to a good pen kit for a first time pen turner. Based on the suggestions here, I picked up some Sierra pen kits from Lee Valley.
I can't believe how easy this was. Here's a picture of my first pen.
Thanks for the advice!
I do have one question for those of you who have made this pen. What do you use for a pen mill? I have a pen mill with interchangeable pilots, but none of them exactly fit this kit.
Re: First pen -- thanks for the advice
Jim Shaver - Oakville, Ont, Canada
>I am so happy for you my friend, that looks perfect! You see, how hard can it be??
As for pen mills, I have one JUST for Sierra's, got it from www.penblanks.ca , A good source for supplies as well
I am pleased that you took a chance on making a pen and have such a positive result..
So when will we see more??
Take care,
Jim
Jerry Whitaker
>Wilbur, I use the same pen mill for everything. I got some 7mm tubes and glued them into a piece of wood and then turned them down to the proper sizes I needed....in the case of the Sierra, just turn it to 27/64 which fits into the Sierra tube and slip it over the 7mm shaft. This will keep everything in alignment.....and it is cheap!
Steve Kubien
Steve Kubien
>Nicely done. But wait...pen turning is highly addictive. Regarding mills, I tend to buy the ones for specific kits. Ya, it's more expensive this way but they are also handy for disassmebling pens that aren't up to snuff (so I've heard. Afterall, each pen I've made has been perfect. Ya right!). When necessary I will make a mill adapter like Jerry suggests. The only one I can think off the top of my head is for the El Toro (and I can't remember which end).
Cheers,
Steve
Check AZ
DavidWalser
>Arizona Silhouette carries barrel trimmer sleeves for the Sierra kit for a price of $3.50. (They also carry sleeves for other kits.) Here's a link (scroll down): AZ Silhouette
Yes, you can make your own. But $3.50 is not much to pay, considering the time it'll save you.
Re: Check AZ
Jim B
>Here is a link to one from CS in Utah.
http://www.woodturnerscatalog.com/store/Pen_Making___Pen_Making_Tools___Apprentice_Barrel_Trimmer_Kit___barrel_trim_kit?Args=
Thanks again for the info
wilbur
>I wound up getting an adapter sleeve for the Sierra from PSI. They have a version of the Sierra called the Gatsby that looks a bit different but has the same dimensions as the Sierra. I needed to get some other stuff from PSI, so I rolled in the adapter sleeve into that order.
Thanks again for all the comments, and I have to make some more pens this week for gifts, so I'll post some pics.
