Photo battle continues...
Marc Phillips
>OK... here's what I have so far... and thanks to all for the help....
I now have the camera set for a "Custom" set up... and I was able to scroll through the menu and set the camera etc. for the following settings.
ISO 50
White balance - set with a white piece of paper
Pic size and quality are set at the max size and quality
2 second delay on the timer.
Digital Zoom off
Room light turned off
Still quite a bit of light coming from the window but closed the blinds.
Light is as far in the right-front as I can get it, bowl is positioned where you see it in the other response with the pic of my phrugal set up.
Camera as close as I can get it, and zoomed in with optical zoom until the whole bowl filled the screen, THEN set white balance... this seemed to have the greatest affect on the initial pic quality.
Still seems to be out of focus... gotta keep reading and reading and experimenting until I get this...
Thank you all... still working on it but getting closer....
Re: Photo battle continues...
Using Auto Enhance
Marc Phillips
My phrugal set up....
Marc Phillips
Re: Time to tweak- I'm not sure why....
Jamie Donaldson
>...your initial image seems to be so hazy, but now for additional adjustments. Set the camera exposure compensation to +1 due to the white reflective surfaces, and you are losing light with the L side of the enclosure open except for the bounce board. Center the turning in the enclosure, forget the stand, and the backdrop is not far enough away from the turning- my backdrop hangs and extends about 2' behind the enclosure. The point of critical focus for max. depth of field is 1/3 behind the front of the bowl, and DOF is 1/3rd in front of the point of critical focus and 2/3rds to the back. I'm not clear about why you said the camera is as close as possible, when using the max. zoom setting to crop should place the camera further away, and why you made a 2nd white balance adjustment?
>Have you tried cleaning the lens. It looks like flare which is softening the image. This usually means either a dirty lens or stray light coming into the lens.
Time to tweak- tweaked...
Marc Phillips
>OK... did all you and John said...
One thing that may still be wrong is the compensation... I think my camera, when you choose "+1" does not compensate but actually increases the exposure by "+1" ... so will play with that some more...
OK... raw pic in this post, and adjusted pic in response...
Getting closer all time! ... please keep the instructions coming... these pics are improving in leaps and bounds now!
Tweaked with software....
Marc Phillips
Re: Tweaked with software....
>Mark Could you send us a photo or drawing of where you have the lights, tent, etc. It still looks to me like you have an awful lot of light behind the piece which is making the background very bright. This is creating flare around the edges of the bowl and probably softening the contrast. A photo of the light set up would be best. I think Jamie and I can help better if we see exactly how the light is set and how it's bouncing around, etc.
>Thanks, I did miss it. Move the bounce card on the right side out further so the bounce light is coming more from the front. I think much of the problem is the light is coming so strong from the top and back. You my be able to improve it by aiming the light more toward the front panel and side right panel.
Just for fun, try shading the top of the lens with your hand on the next photo. Don't get your hand in the photo but try to cast a shadow from the lights onto the lens using your hand. That may help the flare situation of that is what's happening.
Re: Increasing the exposure by +1....
Jamie Donaldson
>... is exactly what compensation means, so leave it as is. There is too much light on the back R side and not enough in the front, and that's partly due to the confines of your background being too close to the turning and light source. Also adjust the bounce card on the L side to aim more light into the shadows on the L front of the bowl, filling the shadows.
Re: I considered the dirty lens.....
Jamie Donaldson
>....theory John but thought it might be too obvious a solution!
