Why Airstream - Beacuse its Worth it
Fog Tanner
>There is a big difference between the two in what you get. There is also a big difference in the specs. What may appear to be small in the filtration numebrs are large to your lungs. I have a Powervisor, which is the predecessor to the Trend unit. It was replaced with an Airstream. I am in it for upwards of 13-14 hours at a time with no neck problems. The balance is much better than the Trend, with the weight balanced front to back instead of being all front loaded. It takes all of about 5 minutes to get used to, after that it is uncomfortable to turn without it.
Filtration is the main element, the Airstream will go to the submicron level, and the Trend will not. Like the Powervisor, the Thrend is rated for nusience (sp?) dust. This is the dust that your body will trap normally. The submicron dust is what does the damage as it passes right through your airways into your lungs. So even with the Trend stopping the larger particles, you still get the harmful dust.
The CFM ratings are much different. The CFM rating that the Airstream has to meet are a minimum of 6 CFM for the duration of the service cycle. The AS400 that I use has a higher CFM for the entire cycle. The Trend starts out at around 5-6 CFM and quicly drops within a few minutes to a lower flow where it will maintain for the majority of the service cycle. The Airstream has a belt mounted 5000-5500 ma battery, where the Trends has around 750 ma.
There is also the added benifit of the helmet. For me this is extra body armor for the skull. It is not if, but when that piece will come out of the chuck and off the wall right into skull, or just explode due to and unseen crack. Have had both happen and will not turn with my Airstream.
If you search the archives for Airstream and dust you will find a large number of replies on the why its worth the extra money. For me, I have become accustomed to the use of my lungs and would like to continue without the aid of a bottle of oxygen or a lung transplant. That is why I also have an Oneida cyclone, which is also submicron. My lungs are much happier these days. Without the Airstream, I would probably not be turning now.
Fog
