Frustrating...
Frustrating...
Frustrating...
Marc Phillips
>Once again I apologize for my earlier post... It was out of line.
I am getting really frustrated at this... I had pretty good pics before, but there was always the glare of the lights showing on the turning I was shooting...
Read tons of stuff on the web, and bought the tent... and the pics got worse...
Posted here, and was told to build yet another lighting setup... *sigh*
So... OK..... made a "frugal photo setup" that was suggested here...
http://jamiedonaldsonwoodturner.com/techniques.html
I built it, but am still struggling with getting a good pic....
Man, this is confusing!
Copied the setup on that website, and now here is where I am at... not sure but I think it might be the white balance .... can't seem to get it to look like the old pics I used to take....
This pic is the way it came from the camera, the next pic is after enhancing....
Re: Frustrating...
After enhancing
Marc Phillips
>OK... will try and ask a specific question here...
When I took pics before all of this, I set the white balance by holding a white piece of paper in front of the camera and hit the button on my camera and the camera would set the white balance for me...
Now it doesn't seem to be working... I am getting these hazy looking pics...
Anyone have any idea?
Re: Frustrating...
Re: Frustrating...
Doc Green
>Marc, my first thought is that it's underexposed. I have a Phrugal setup (500 watts) and set my exposure at shutter priority, 1/30 second, camera on a tripod. Also try setting the camera to do an overexposure by +0.3, +0.7 f-stops to see if that makes a difference.
Another possibility is lens flare in conjunction with underexposure. Make a cardboard tube to slip over the camera to eliminate as much bounce light hitting the lens as possible. Lens flare will give a hazy image.
Do you have a reflector board covering most of the front of the tent? Try it, to get more light on the front of the object.
Bring the light as far foward as you can, or, push the object as far back as you can in the tent.
I first tried the Phrugal setup, then went to a more complex system of lights, got headlights, and then back to the Phrugal. The Phrugal will work if you can whip it in line. Keep the faith.
~Doc
Re: Frustrating...
Something is goofy
>That image should not have come from the camera that way. The color temperature is off. The contrast is off. I'm no authority, but I think you might want to try a different camera, just to check. Or, there may be something in your camera's menu settings that is causing the loss of contrast.
Re: Frustrating...
Re: OK Marc- let's talk specifics. In .....
Jamie Donaldson
>.... this image the color balance is obviously way off- looks like the camera was set to daylight and the shot was made in shade. If you were previously using a custom color balance by reading from a white board, the color should be better if all conditions are equal. The next step is to make a custom exposure correction of approximately +1 to compensate for the high reflectance of the white background. Using an 18% gray card for both custom color and exposure correction readings will be even closer to actual representation. Did you note that the light was pointed up at the top in the Phrugal Photo set-up? That bounces light more evenly about the enclosure, and make sure that ALL other light sources in the area are eliminated, especially windows.This process requires fine tuning, so be thankful that you don't have to wait for the film to be processed between sessions!
Re: Frustrating...
Re:Hey Doc- you should be using....
Jamie Donaldson
>....aperture priority, and set to f11 or f16 if available. That controls the critical depth of field, much more important for our application than shutter speeds. That's the job for a good solid tripod.
Re: Frustrating...
Re:Phrugal is good!
Jamie Donaldson
Re: Frustrating...
Re: Frustrating... *LINK*
charlie belden
>A bunch of questions first
AS I understand the problem, you WERE getting acceptable pictures of this piece
but were also getting one or more Hot Spots
(number of hot spots resulting from the number of lights shining directly at the piece).
You subsequently got a "tent" and are diffusing the lighting through the sides of the tent - and getting what appears to be a washed out, under exposed image.
You didn't mention what kind of bulbs you've got in your light sources. Ideally they should all be the same type - ie all "daylight" or "soft white" or "natural light" etc. - and with the same temperature range - ie 5000K, 6000 K , 6500 K). When you shoot, it's best to eliminate all other light sources. Mixied lighting will make it more difficult for the camera's software to produce a good digital image.
You didn't mention if you digital camera has multiple modes eg. portrait, landscape/outdoors sunny, overcast, night
AND
"macro mode for shotting smaller objects where the camera can be 4" to about 18" away and still be able to focus.
I notice that the piece is pretty close to the backdrop and the weave of the backdrop is quite clear. The auto focus may be trying to focus nearer the back of the bowl, or on the backdrop and setting the exposure and apeture to get the backdrop right - which makes the foreground off. Perhaps moving the piece foreward, farther from the backdrop may reduce or eliminate the focus problem.
It's hard to tell from the out of camera image you posted but zooming to get the piece to fill most of the frame can deteriorate the quality of the digital image.l Better to move the camera closer than to zoom.
If your camera has digital stabilization, turn it OFF and use the Timed Delay feature if your camera has one - and if the camera is on a tripod. This will allow any movement caused by pressing the shutter button to have stopped before the image is captured. And if you're camera has an Auto mode, it may go for a longer exposure time and a smaller apeture and produce a better quality, more detailed image.
You haven't revealed which photo enhancing software you used, or which enhancement feature(s) you used. In PhotoShop for example, you can tweek an under or over exposed image by either using "curves" or "levels" - the latter resulting in better quality and less loss of image data - but a little trickier to use well.
Answers to these questions may provide folks who might have specific suggestions to help you.
If you're up for a little more reading, and looking a pictures, go to the attached link and download the 01_2009.pdf file of our turning club newsletter with a good article based on a demonstration a member gave on improving photographing turnings.
Newsletter with 3 pg on photoing turnings
Re: Frustrating...
Doc Green
>Right on, Jamie! My tripod leaves a little to be desired and my camera (Brownie Super Digital) doesn't have a delay, so I was more concerned about camera movement than depth of field. So, I set the exposure to 1/30 and hoped for the best.
At any rate, I feel like I'm a bit more on top of it now so I'll go back and rethink that situation, and maybe give aperture priority a shot, ... so to speak.
Thanks for your comment. Marc . . . did you get that? ~Doc
Re: Frustrating...
Re:Ahhh Charlie, there are several mis-statements.
Jamie Donaldson
>... in your post. Zooming in to crop or fill the frame has no effect on resolution unless you're cropping the image post capture with software, and never use digital zoom on the camera. Moving in close to a wide angle focal length should always be avoided to reduce barrel distortion in the subject, a characteristic of short focal length optics.
Re: Frustrating...
Question for Marc and Jamie
Dinyar Chavda
>I may be raising a stupid issue, but Marc, you said:
"When I took pics before all of this, I set the white balance by holding a white piece of paper in front of the camera and hit the button on my camera and the camera would set the white balance for me. Now it doesn't seem to be working... I am getting these hazy looking pics... ."
Now for the dumb question: When you are setting the white balance, are you holding the white paper literally in front of, and in close proximity to the camera?
If so, my question for Jamie is whether Marc should be doing so, or whether the paper should be in the tent, either next to the bowl, or where the bowl is going to be placed?
Re: Frustrating...
Re:Dinyar et al- the board used as ...
Jamie Donaldson
>.. a light value standard(either white or 18% gray) should be in the same position as the object being recorded. The light actually falling on the object is the light to be selected for a custom balance, and the reference should fill the frame as much as possible to give an accurate reading for both color balance and exposure.
Re: Frustrating...
charlie belden
>"Sure wouldn't be the first time, and not likely the last." he said with an embarassed grin.
On the loss of quality when using Zoom to get the piece to fill more of the frame, I was thinking of "digital zoom", which many lower end/smaller digital cameras are using in place of actual zoom lenses. And with lower end cameras in the 1-2 MB range, as opposed to the 5, 7 and with the higher end cameras 20+, MB range, the digital zoom software can muddy things up a bit.
Regarding "barrel distortion" when the lense is brought too close to the subject using a short focal length lense, apparenlty camera manufacturers are aware that kids, and it seems mostly girls, are taking pictures of themselves for their My Space page(s) and not real happy about the Big Nose/Small Ears results. So camera makers have added a Self Portrait mode to their cameras which uses software to reduce the barrel effect. I don't know how well this Self Portrait mode works since I don't take pictures of myself.
Photographing pieces is probably the weak link in a turner's bag of knowledge and skills. And if you can't get a good to really good digital image of your work you're less likely to get them in a magazine or get passed the screening process for most shows / exhbits. I'm told that "hot spots" are one of the major elimination criteria.
Gaining adequate digital still photography skills is challenging enough. If you add actual movement to a piece digital movie making skills are needed - and THAT really ups the learning curve ante since the individual "frames" must be captured quickly while the piece is changing its distance from the lense and that may also involve the lighting changing.
Re: Frustrating...
OK.. so I am now going to assume...
Marc Phillips
>.. that I need to take the camera off the tripod get it as close as possible to the subject for the white balance setting procedure... since this phrugal set up kinda made me position the camera back farther.... or does it work better if the camera is in the actual position that the pic will be made when taking the WB reading?
Re: Frustrating...
Re: You should not have to move.....
Jamie Donaldson
>...the camera if the board you are using at subject position for color balance/exposure is large enough to fill the frame.
