Photo help please...
Marc Phillips
>OK... more confused than ever now.....
Bought the large photo tent from Harbor Freight, and used the same 3 lights but no background as before. Lights are positioned the same as before, except now they are shining through the tent. This is the original pic with the usual software enhancements.
Re: Photo help please...
New tent, no software enhancements
Marc Phillips
New tent, with usual software enhancements
Marc Phillips
Re: You're working way too hard at.....
Jamie Donaldson
>...this by substituting equipment rather than knowledge about the subject of lighting. Look at the tips menu on my website JamieDonaldsonWoodturner.com for a simple lighting set-up for shooting turnings with 1 light source.
Brad Vietje
Brad Vietje
>Marc,
This one might be fine with a very simple background -- the fabric tends to compete with the wood.
Safe spinning,
Brad Vietje
Newbury, VT
Despite your last "take-the-hint" post...
Carole Valentine
>I will comment even though I am not a photographer and you have not bothered to tell us what your camera settings were, what type of lights you are using or what constitutes "the usual software enhancements". I have no idea why the picture using the tent looks the way it does...I have to assume it is an exposure problem as well as a slight focus problem. Try bracketing your exposures and increase your depth of field. I would say that your "usual software enhancements" look like an application of "auto levels", which rarely works and usually makes things worse. This should be done manually. In the original photo, I would say there is too much sharpening. You also don't say which software you are using. Not being able to see the actual piece, I cannot tell you how to adjust the levels. The attached is a best guess Photoshop adjustment (for what I had to work with) to the one with no "software enhancement".
Now for a slight scolding...I think you owe the folks at WC an apology for your "I can take a hint" post. You can't expect everyone to jump in and take the time to provide a detailed answer (IF they even have one) when you don't take the time to provide a detailed question, especially when it comes to something as complex as photography. This is one of the most helpful forums on the net, but if you want to take off in a snit, that's your prerogative.
Re: Despite your last "take-the-hint" post...
Carole Valentine
>Well, I suppose I wasted my breath and 30 minutes of my life on that post. And people wonder why others don't spend a lot of time responding to vague questions? Such is life. At least you did offer an apology to the community. Hope you get your problem solved.
