Lathe mobility
Lathe mobility
Lathe mobility
Bill Youngblood
>Hi All,
Our chapter, The Bluewater Area Woodturners, has purchased a trailer for hauling our equipment around to shows, demos, and the like. I'm wondering if anyone has any suggestions or ideas for mobilizing a Jet 1642 without dismanteling it. We are looking for a way to get it up and down the ramp on the trailer and in and out of buildings. As with most chapters, our average age is 60+ and it is pretty tough taking that monster apart. Thanks in advance.
Bill
Re: Lathe mobility
Steven Antonucci
We have our Oneway 1224 on locking casters
steve antonucci
>Depending on how finicky you are, a good set of casters should solve the issue. Some folks jack the lathe up and down to remove them once moved, other just wheel and deal with vibration from the lathe being on wheels.
Once the piece is balanced, locked casters are pretty solid. Expect to pay about $50/ea for good ones...
Steve
Re: Lathe mobility
Rob Wallace
Re: Lathe mobility *LINK*
Rob Wallace
>Bill:
You might want to have a look at the wheel kits for lathes that Oneway sells, and adapt your Jet lathe with something similar (LINK BELOW). Larger pneumatic tires on castors would be the way to go, to get over sidewalk cracks, expansion joints, driveway ramps, etc. - I've made lathe moving platforms with smaller castors/solid wheels and can tell you they don't work nearly as well.
Good luck,
Rob Wallace
Oneway Lathe Accessories
Re: Lathe mobility
Mike Mills
Re: Lathe mobility
Mike Mills
>I hope my verbiage is better than my drawing.
In short, imagine a toy wagon (cart - no sides). Now cut it in half.
Each half slides under the lathe from the inside and under the brace at the legs.
There are pipe sections affixed to each side where they will meet.
There are small stop blocks (1�) on the outside edge of the frame
to keep the lathe from sliding off.
When under the lathe the half carts will be angled up. Step on the center and it will raise the lathe on each end, slide a solid bar through the pipe to lock the two sections in place.
You will have to fiddle with the height at the ends
to get it right, you probably want to raise the feet of the lathe about an inch.
Basically you are making a lever(s) with wheels.
The front set of wheels would have to be closer together for turning radius.
When ready to use, step in the center again and remove the locking bar and lower slowly. Then just slide the two sections out.
You may have to make the �steering handle� removable in order to slide than end under the frame brace on the lathe.
I agree that pneumatic tires (at least 8 inch) would be best, unless you get a flat. A hard rubber tire on steel rims would also work.
Mike
Re: Lathe mobility
Re: Lathe mobility
leadpipe58
>There are pneumatic mobile bases out there.I saw one on A table saw and mover it with one finger.The problem is it must be on A flat surface and it would not work on A ramp.Just thinking.
Re: Lathe mobility
Re: Lathe mobility
Scott in Socal
>I've seen the harbor freight hydraulic lift tables used a lot for moving lathes. You just jack it up under the bed, move the lathe, then set it down wherever you want it. That way you're sitting on the actual lathe feet, and you can use it for lifting heavy wood and such too!
Re: Lathe mobility
Re: Lathe mobility
GaryG in MD
>Bill,
I have no space inside my house to turn, so I wheel my Jet 1236 outside onto the back patio for use, and back inside for storage. I have it on locking castors attached to some 2x6's under the standard bench feet. I'm 6'2", and this brings it to just the right elbow height for me. With a reasonably balanced workpiece, this provides a completely acceptable solution -- I've never had any need to add sand bags, etc. I'm 65 years old, and I can easily handle the whole thing by myself -- including lifting it over the sliding glass door track. I know the 1642 is a bit heavier, but two people should be able to do it easily.
...Gary
Re: Lathe mobility
Lots of ideas in this *LINK*
Jerry Hall
>link. All of which could be used on the 1642. The idea under my name in fact was used on my friends 1642 and works great, but has to be custom welded.
Modilbity Options
Re: Lathe mobility
Re: Lathe mobility
Pete in Holland, MI
>A few tips:
1) Large wheels roll easier & over greater floor imperfections than smaller ones.
2) Build a frame for the lathe to set on. Don't just simply anchor wheels to each set of legs. You're inviting disaster if the front set of wheels suddenly stop on something while pushing the lathe somewhere (snapping off the legs).
3) Solid rubber or urethane face wheels won't mark up floors as bad as solid steel casters, but also take more effort to push.
4) Suggest some crank-up feet to help stabilize the lathe while in position.
5) Build a steel frame guard on the back of the lathe, or have the bottom frame big enough. You want to avoid clipping a door frame with your motor frequency drive.
6) Replace the stock electrical cord with one of adequate gauge size, but 25 or 50' long. Will prevent using an under-size cord while on location and risk your electrics. Use a bright color cord too (for visibility on the floor).
My 3 cents worth (adjusted for inflation).
Re: Lathe mobility
Re: Lathe mobility
Bill Youngblood
>Thanks Everybody, Once again you guys came through. I think we will probably go with the hydraulic unit from Harbor Freight. Thanks again.
Bill
Re: Lathe mobility
Chip in Plano
>I just got a 3520 and this is what I'm looking at. I'm not going to invest the time/money to build something that'll raise the lathe higher. I'll remove the handle and put holes in the top for some removeable cleats to stablize the lathe while suspended. By the time I spend driving around purchasing all the components to build a mobile platform, I'd loose a weekend worth of turning still need a friend just to mount the tool...and still be dissatisfied with the effort. That's my perspective.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200365531_200365531
Re: Lathe mobility
Re: Lathe mobility
Bill Youngblood
>Hi Chip,
That's exactly where I went. You might want to check the unit at Harbor Frieght. It's 1000 lb. capacity and sells for $219.99. I saw it on Jerry Hall's responce. Thanks again to all who responded to my query.
Bill
