Finding platter blanks
s.ponch
>Anyone know of a good source for platter blanks or lumber 2x12 or wider. I can't find anything that wide. I would prefer domestic kiln dried wood.
s.ponch
Re: Finding platter blanks *LINK*
Thad
>I'm sure others will direct you to exactly what you're after, but I've used an ebayer called NCWood before. Most all their stuff is waxed green, some domestic, some exotic. I went by and picked up the blank on my way to the in-laws. I'd use them again.
NCWood on ebay
Greg Haugen
>I'd look in your Yellow Pages for lumber suppliers. Here in Southwest WI. we have MacDonald Owen, link below. Often times these places are "by the board", 8ft usually. It's not uncommon to get 2" or thicker boards that are 14" to 20" wide. They also do some rough processing of 4" thick Mahogany for an acoustic guitar manufacturer for the "necks". There's often pieces that are 14" to 20" wide, and even up to 26" wide that are the "off cuts".
Point is to ask around, you never know what's available.
I've also had very good luck with Curious Woods/Curtis Lumber before as well. http://curiouswoods.com They do have some thicker "lumber" but you're able to buy it by the lineal foot.
MacDonald Owen
Lan Brady
>I agree with Thad. I dont buy much wood. But the few pieces I bought on ebay came from NCWOODS and is great. Their prices are very good when you comparison shop. I did not know you could go by their place though, I will try a visit on my next trip to that area.
Lan
Rick Allen
>What if you made platters out of 4/4 stock? Would you have better luck finding wide stock that thick?
What if you jointed and glued two boards together with a contrasting piece of wood between? Could you find 4/4 stock that was 6" wide or wider?
Yes there is a lot of appeal to making platters out of 8/4 stock that is wide enough to yield a 14" wide platter. But that tends to limit your selection.
This 17" platter was made out of 5/4 8" wide stock.
This 16" platter was made out of 4/4 7" wide stock
You should avoid wood that isn't fully dry as a small warp in a platter will result in a big wobble.
Not the usual answer...
steve antonucci
>I had a dining room chair fall apart on me. It was some cheap import from Malaysia, and I would describe it as "wood of an unknown species". I took the 4 legs and used them for spindle practice. I took the seat and bandsawed it round and turned a platter from it.
Now when I see people discarding furniture, I always slow down for a look... Free turning stuff and firewood.
Steve
bernie feinerman
>Constantine's, on Oakland Park blvd in Ft. Lauderdale often has wide wood which can be used for platters. I have bought 2" mahogony 20" wide from them.
Re: Not the usual answer...
robo hippy
>Steve,
Made in Malaysa, small pieces finger jointed together, and light colored is rubber trees.
robo hippy
Pieces weren't that small?
steve antonucci
>I think that there were either 2-3 boards max in the seat. I would have guess some kind of Palm, but it would have only been a guess.
Wood was almost white with the classic straw like characteristics running through it.
It was either turn or burn, and when the rest of the chairs break (again), they may suffer the same fate. 2 for $25 is hard to pass up...
Barbara Gill? : )
Ruth Niles
Dick Hines
>I got a big piece of ambrosia maple from Gary at the 2007 NC Symposium. I called him and told him what I needed. He brought it to the symposium all waxed and readt to be turned. He was very easy to do business with. Looking foward to seeing him in NC this Oct.
