Segmented Bowl
Segmented Bowl
Segmented Bowl
Carl Barton-VA BCH
>Finsihed up another bowl this morning before it became too hot in the shop. I went out a few minutes ago, the temp gage said 100, glad I finished this morning.
Tried a new design on this one, measures 7-1/2 dia, 8in high, soft maple and purpleheart. Comments welcomed, still need to work on my photo's.
Carl
Re: Segmented Bowl
Is that soft maple endgrain in the middle
>with the purpleheart?
Re: Segmented Bowl
Re: Is that soft maple endgrain in the middle
Carl Barton-VA BCH
>JL,
Nope, just a different board than the rest of the bowl. I started the feature ring from another board I had, trying to use up all the wood I had on hand when I was trying this design. After four attempts to get the design just right ( I can still improve) I ran out of maple and had to get more.
Carl
Re: Segmented Bowl
Texian
>Good question JL. Interesting feature ring with good looking joinery. Appears to be one suspect joint near the top of the piece and some minor misalignment above and below the feature, which may just be some digital disfunction. In any case, a great looking piece from here.
Re: Segmented Bowl
Misaligned
Carl Barton
>Texian,
You are correct, the rings are misaligned a bit. I did not pay attention like I should have. This is my 10th segemented turning but with each one I feel I am getting better.
Carl
Re: Segmented Bowl
Re: Misaligned
Texian
>Easy to do, as there are about four things to be focused on at the same time and it's easy to lose track of one of them. I really like your feature ring and am curious how you made the curved joints. From here they look like perfect joints.
Re: Segmented Bowl
Re: Misaligned
Carl Barton-VA BCH
>Yes it is easy to do that but I am committed to do better the next time around.
Trust me when I say the inlays are not perfect. It took me three different rings to get to this point and still one or two of the circles are not perfect. Of course in my wife's eye they are, but in mine it is another story.
The ring is not that hard to do really, just very time comsuming. I look at allot of web sites and found one by Bob Pricthard. He started doing this ring design about 10 years ago and he has the procedures on one of his web sites, with some other helpful hints. If you are intrested here is the URL
http://segmenting.biz/drillpressinlays.html
The short of it is you drill holes (1-3/4 for the one I did) plug the holes ( 1-3/4) with desired wood. Cut the segements, glue up, then cut the ring in half and rotate the halves to off set them, glue them back up.
It is easy once you get the hang of it, but as I said, it took me three tries to coming close to perfect.
Hope this helps.
Carl
