>Tried turning my first small finial the other day and found that I needed more than reading glasses to see the details clearly. Was considering some method of magnification and wondered what others were using.
I have seen two items available through the mail order sources. One is a articulated arm light/magnifying glass lamp. The other is a headgear that has various powers of lenses available.
For those using the headgear, how did you determine which magnification to go with? At $25 per lens, not something I want to do a lot of trial and error with.
Most of the maginfiers that are worn on the head use the same lens powers as the drugstore reading glasses, such as +1.5 or +2.25. Try on the glasses at the drug store to see what magnification power you need, then order the same power lens for your head gear. It should be pretty close.
>I do use the circular fluorescent lights on articulating arms that have a magnifier in the middle. We buy these at Hobby Lobby with the 40% off coupons my wife gets via email from them about every other week (IIRC this puts price about $26 dollars after coupon). I don't actually turn looking through the magnifier but will stop the lathe and look at work done - the more gray hair I get the more I use them!! I have never had a problem from fluorescent lighting in the shop on lathe work and enjoy these lights so much that I have something like 4 of them at various workstations. My wife also uses them on her quilting and has them mounted in her quilting room, have not counted her's lately!
>My choice is the mageye listed in the link above. (The green ones for $29.95) It's very lightweight and easy to use. Weight becomes an issue if you use if for long periods.
I don't recommend the lighted single magnifier. It doesn't give you as good a stereo vision so your movements aren't as controlled. It gets incredibly dusty so you have to clean it all the time, and you have to find a way to mount it.
The mageye listed above is easy to put on, and remove. You can get different magnifications if you find you need it, they flip up out of the way and they are apparently pretty tough judging by the way I abuse mine.
The downside is if you have bifocals you have to learn to look through a certain part of your glasses to work affectively. It doesn't take long to learn that.
I do like reading glasses but they don't protect your eyes in an accident. with the mageye I can wear my safety glasses and still use the magnifier.
For serious detail work purchase a Stereo Microscope but you do have problems with mounting, cleaning etc. If you need 20x magnification that's the way to go.
>Yep, I have 2 pairs. One is a pair 1.0 I use as readers and arm's length work like turning and posting forum messages. I have another pair that are 2.75? that I use for really getting in close. I'm blind as a bat so I also wear contacts full-time. I couldn't begin to tell you what my combined focal power is with the 2.75 ones on. I wear a faceshield, too, so sometimes I just peer over the top of the glasses and turn, too.
>As Chip indicated the issue is focal length. You will need to find what magnification works at the distance from the lenses you will be working. Something to keep in mind: I was wearing lenses to turn a cove in a very small finial. I created a dig at the bottom of the cove and worked for a long time to try to turn or sand it away. Finally I realized that without the magnification no one would ever see it.
>I use a visor from Harbor Freight that I am pleased with. I use it primarily to check for defects and scratches when sanding. I rarely use it when turning (I use my reading glasses, instead) because the visor will not fit under my face shield. However, when turning fine details, I will just use my safety glasses and omit the face shield if I need the visor. One of the nice things about the visor is that it allows you to switch between any one of 4 sets of lenses by flipping the desired lens set down. The higher power lenses require you to get fairly close to the work -- too close to be comfortable as a turning position for an extended length of time, but tolerable for refining a detail or two.
>I use reader safety glasses for all my turning and shop work. I normally use a 1.5 but have a pair of 2.5 for smaller detail work. At 6.95/pair I keep several around.
>There is also great difference in optical quality of lens. I bought a cheap pair, it makes me dizzy when using it. The pair that I replaced it doesn't cause the strain to the eyes. The extra $20 is well worth it in my case.
