A little help on Urns Please
>I have been scoping out a Crematorium that offers its services to pets, well the owners of pets that have ceased to be.
I have a chance to make some urns. Where can I get more info? As in, should they be bottom hollowed and sealed with a permanent plug that glues in or should the plug screw in?
How do you measure the volume? I was thinking of filling it with rice or dried beans and then measuring them.
Any ideas on designs that sell well?
There is a place nearby that does laser engraving. What opportunities does this present.
Re: A little help on Urns Please
Pete in Holland, MI
>1) Check E-bay for various people with urns for sale for ideas.
2) For humans, volume calculator, I understand, is 1 cubic inch for pound of "meat".
3) Measuring with beans, or maybe rice, will get a good idea on resulting volume, but that is after it is turned. Probably otta figure out how much diameter & length will create the volume you need first, then check afterwards. Using a measuring cup, 1 pint = 28.875 cubic inches of volume.
4) The couple urns I have made have bottom access only. Made a screwed on plate designed for some sealant. I don't really see the need to look at that the ashes once they are put in.
Ed Moore in SW VA
>Barry,
There is a poem called "Rainbow Bridge" that is quite touching. Some pet owners might want that poem lasered onto the urn of their choice. If you aren't familiar with the poem I suggest that you Google it and check it out.
I had a chance to make some pet urns and declined because I am not tough enough for that. I made one and that was sufficient for me.
Ed
Dick Hines
Dick Hines
>I saw one at the Tidewater Turners meting that had black pipe threaded fitings attached into the urn and the top. The top covered the plastic so it could not be seen.
Barry talk to Danny. He has made some urns.
Russ Fairfield
>The only difference between an urn and a lidded box is that the lid is securely locked in place. It cannot be easilly be removed and WILL NEVER come off if the urn is dropped.
People will appreciate a little showing of skill and ingenuity in the locking device. Some do that with threads, while others use something more secure like screws or pegs to hold the lid in place. I use a built-in half-twist lock on the lid with a single screw to keep it from turning, and have no problem with selling this feature.
Ric Taylor
Ric Taylor
>I'm getting ready to make several urns myself.
I know that some people make urns with threaded lids or bottoms, which is a nice feature, but I can't figure out why anyone would do that. After all, there won't be any need to open the urn ever again.
There are some instances, particularly with couples, where there is a desire to be placed in the same urn together. In that case, a threaded lid might be a good option so that it can be opened when the second person passes.
All of the funeral homes that I know of use epoxy to seal the lid closed.
Ric
Mike Stafford
Mike Stafford
>I have made a few pet urns. All of the ones I have made incorporated a decorative lid feature that was not operable and a plug for the bottom that was glued into a recess after the urn was filled. The plug, in some instances allowed the owner to inscribe some details about the pet. Artificial ivory discs make a fine insert for such details to be inscribed upon in the fashion of scrimshaw. As a matter of a fact I have a scrimshander friend who does it for me.
Russ Fairfield
>Folks like the idea of being able to open the urn at a later date so the ashes can be spread on a significant place or divided up among the remaining family. Having a secure and child-proof, but accessable, lid does that.
Jerry Whitaker
>Attend the SWAT symposium in Wichita Falls, TX October 16-18 and you can see Mike Mahoney do a demo on urns.
Re: A little help on Urns Please *LINK*
Barbara Gill, Remlik VA
>Before you count on your engraver, make sure the laser unit will accept something the shape of a urn.
Several years ago I spent a lot of time dealing with an engraver on the Southside. I was going to have several plates engraved for some graduates of the Naval Academy, including my Nephew. When it came time to do the actual work he discovered his bed would only drop enough to accommodate 1". The 5/4 plates would not fit.
AAW Post
Re: Scattering Urns?
Bruce McElhaney, Spring Lake, Michigan
>As far as a reason for opening or re-opening urns. . . Some urns are made to be opened for scattering the ashes. Of course there are urns designed just to hold ashes. But there is no reason why an urn can't be made for both purposes. Most often such urns use a secure threaded or locking top. Mike Mahoney has a great video showing how he makes an urn for a dog's ashes using a hand chased, threaded collar and finial.
Russ Fairfield
>There ya go. With the demo and $1000 worth of new tools, you will be in business.
George Taylor
George Taylor
>For inspiration you might want to look at a recent exhibit at the AAW museum in St. Paul; here is the link.
George
George Taylor------WebKitFormBoundarynkEfFBPsAQeQ+
>Try again
http://www.galleryofwoodart.org/RestfulPlaces.html
