A55 Smoothing Plane
Yet another PM3520 Mobility Solution *LINK*
Jerry Hall
>I have added my variation on how to move the Monster. More pictures, commentary and technical drawings on the link. Also lots of other good ideas for walking the 3520 around. Note that I especially swept up my shop for this quality pic.
Jerry
Custom Feet: See middle of page
Re: Yet another PM3520 Mobility Solution *LINK*
charlie belden
>A bit more expensive - but you can adjust them from above - with an allen wrench.
A little 80 grit psa sand paper on the bottom and you've got a good grip on the floor.
Leg Leveler - adjustable from above
Jerry Hall
>Thanks Charlie. Good option. To be clear, the nut that on the top of the 1/2" All-Thread is welded on, but lock-tite would do the job. Next time I would include a washer below the nut, maybe captured between two nuts, so I could easily use a box wrench, but I keep handy a ratchet and socket which does the job nicely. But I am sure an Allan wrench would get it done too, and be easy to store in a handy place.
Not to sure about the sandpaper. On my epoxied floor at least the soft rubber of the feet provides a nearly immovable grip. But for some the sandpaper may be worth a try. As you can see I have a pristine shop, and would not want to scratch my floor. :)
Jerry
>I may try the solution above by may bolt the wheels to the leg. I'm short and have to keep the mobile solutions as low as possible. Adding even a piece of angle iron starts to raise the lathe too much. One of the lathe mods I was talking about is a mobile solution. I'm going to work on designing that soon. Thanks for posting this one.
John, building on your idea and needs
Jerry Hall
>Something to consider, as you most likely have: The 3x3 x 1/4" thick angle iron shown in the drawing only adds 1/4" in height. The rest is the minimum clearance (maybe 3/8") you would need in any case for the wheels to clear the bottom of the leg and to make it over a floor with minor peaks and valleys, not to mention loose tools and shavings. So all you will save IMHO by bolting it to the side is 1/4" and then you lose the much improved fixing and bearing of the angle iron to the legs on the side and under the leg. I suppose you could use two bolts on each leg and that would get it done, but that would be the sole support for the lathe when turning. Maybe you go to your shoemaker and have him put a 1/4" sole supplement on your shop shoes, or do it your self with some Goop :)
Another idea is to have the angle iron go all the way across, attached to the outside end faces of the legs, and maybe wrap under the leg bottoms also, with wheels only on the headstock side. Then put a angle iron on the tail stock side with the adjustable feet only. And use a custom Johnson Bar/Tow-bar with wide stance dual pivoting wheel and steel dowel to hitch and run the monster around. It would be stable as long as you remember to have the headstock all the way down toward the wheels. You may have at least one of these already, as I do for my Laguna Band Saw and combination machine.
Jerry ("The principle cause of problems is solutions....")
extended stance
>Jerry I was thinking along the lines attaching the angle iron parallel to the floor and going across both feet and extending a little beyond to give a wider more stable stance. My friend did this when he was turning really out of balance pieces except his extension was 3 feet on each side. It reduced the lathe vibration and walking to almost zero. He used 1/2thick angle iron. Even though it worked that was too far and easy to trip over.
I was thinking about extending it just a few inches on my side of the lathe and about 6 on the other. The leveling screws would be attached on the side so I could leave the iron just barely off the floor. The feet would then be hinged and require a lever to lift each side and drop the feet in place. I may make the wheels removable similar to Oneway because I would love to have big inflatable wheels to make it easy to move since I could work outside on really good days and my lathe is only 3 feet from the garage door.
Chip in Plano
>I guess I'm a simpleton but I need a KISS approach. I have mine on furniture sliders for now. It's a good workout moving it but that's what the kids are for, too.
Furniture sliders
Jerry Hall
>Nice simple idea chip for the occasional move. Do you keep them under the legs all the time? If so does the lathe stay put when turning big stuff? How hard really is it to push around for a no kids guy, and do the sliders stay with the leg? How far are you comfortable moving it? Pic?
