2 birds with one stone...
Marc Phillips
>OK... this worked out pretty good!
First off, I was never really able to get the Veritas scraper burnisher to work... so it sat in a drawer for quite a while... Cleaning up today I pulled it out of the drawer, went to the internet and read up on it, found out the problem was operator error :) .... and mounted it to the workbench and did my large scraper... awesome results! ... works great now! I have a nasty old piece of pine that is a jam chuck... and somehow it came out smooth, and it NEVER comes out smooth!
Second - I have had the Sorby Spindlemaster I bought a long time... pretty much found it to be totally worthless... BUT... with the new found knowledge of the Veritas burnisher, I went ahead and flattened the back of the Spindlemaster and burnished a hook on it like a scraper with the Veritas and voila! ... makes a very nice shear scraper... even the shape seems to work well and the rounded back makes it real easy to roll over onto it's side for shear scraping.
Thought I would share in case I am not the only person in the universe with either a Veritas scraper burnisher or a Spindlemaster gathering dust...
Re: 2 birds with one stone...
What did you do different?
>Inquiring minds want to know. I don't own one of the Veritas burr raising tools but have considered building one. I haven't had any problems raising a burr on my tools using a diamond hone but I'm always willing to learn something new. What do you think you did differently to make it a successful tool? Thanks in advance
And another question?....
>I have all of those things. the Veritas thing is in a drawer somewhere and I have forgotten why it faded out of use, maybe it did not live up to my expectations. I also have a large scraper and the Spindlemaster or whatever it is called. I enjoy both of my scrapers, but maybe they could be better. Exactly what did you watch that made you a convert. Could you post a link?
Re: What did you do different?
Marc Phillips
>"What do you think you did differently to make it a successful tool"
2 things actually.... and I sure wish I could remember where I read this... I will try to retrace my steps on the internet to find it....
..... anyway...
First thing was to grind the angle... second was flatten the back on a diamond stone... and third was to turn the burr on the Veritas thingie (technical term) using a LOT more pressure than I tried last time.
Interestingly enough, it was actually very quick and easy.... as is most things when you do it right :) ... 3 passes across the thingie and there was a very nice burr...
Typical of me (I am sorry to say) is that I order something like the Veritas thingie, clamp it in a vise, try it on a scraper without any preparation at all, and instantly decide "it sucks" and toss it in a drawer.
This time I did it right... and lo and behold it worked! ... imagine that ;)
I can honestly say that the burr the thingie raises is impressive (to me) and the shavings were very nice little feathers floating around... I was happy!
Re: And another question?....
Marc Phillips
>I am trying to find the link without success... but what it boiled down to was just doing ALL the things required rather than what I did when I first bought the Veritas... that is; grind the bevel, then flatten the top, then turn a burr using quite a bit of force... when I first got it I didn't even mount it on a bench... just stuck it in a vise... it works a lot better on the bench....
Here is a couple of links....
http://www.fine-tools.com/G307858.htm
http://www.leevalley.com/shopping/TechInfo.aspx?p=41594
Hope this helps... truthfully, now that I just followed the directions, I feel pretty silly and just hoping to help someone else who maybe did the same thing I did.
Re: Burnisher
Ron McKinley
>I just got the Don Derry burnisher and the key to that is to run it through at about a 15 to 20 degree angle--not level. This puts the burr a little off the edge rather than directly above the edge, according to Don. It really works well and the burr lasts a lot longer compared to a grinder burr....Ron
Re: Burnisher
Marc Phillips
>The Veritas has the burnisher at an angle already... actually, the burnisher itself is angled.
>Thanks Marc I polish off the burr each time before I raise a new one. Over the years that has more or less polished the top of the scraper and flattened it. I can raise the burr with the diamond hone 4 or 5 times before I feel like I should go to the grinder and re-establish the front grind.
I've read that the Veritas makes a larger burr that may last longer but that's hearsay.
Marc Phillips
>I wont be able to compare... too bad... that would be a pretty good comparison.
If you can describe how you raise the burr with one of those diamond paddles (I use them) then maybe I could do some sort of comparison... might be interesting. I do know that this burr works a lot better then the one I normally use... my scrapers "worked" before, but truthfully I had no idea how badly they actually worked now that I have had some turning time with a scraper with the burr the Veritas raised.
>I use the EZ-lap diamond hones. I lay the hone flat on top and polish off the old burr. Then I simply run the hone up from the bottom of the bevel toward the top about 3 or 4 times. I don't rub the bevel with the hone but lift it off so it's running at about 85 degrees or just 5or more degrees off vertical if the gouge is horizontal. I use the purple/medium hone most. The finer hones produce a finer burr and this is good for some things but the medium is used about 90 percent of the time.
Marc Phillips
>Thanks John... I was wondering what you did to get that burr with the EZ lap..
I will try it... and compare with the veritas and see how it goes...
