Porous wood/Salad bowl Question
>I have made what I thought was going to be a working salad bowl for a friend. I don't know what the wood is. My son gave me the blank. It was found wood in Florida after a hurricane. The wood is about the color of walnut but more coarse and at least as porous as Red Oak. I can easily blow air through the end grain sections of the bowl. The open pores are clearly visible. The question is: Would you use such a bowl as a salad bowl? (The mixing bowl, about 10" X 4 1/2", not the smaller ones you eat out of.) If so, what would you use to seal/finish it?
Re: Porous wood/Salad bowl Question
Re: NO
Russ Fairfield
>Why take a chance? If it leaks air, it will definitely leak salad oil. Call it "Art" and put it on the shelf to occupy space and look good.
Rick_Allen
>You can seal up the bowl with epoxy. A good deal of effort is needed to use epoxy.
Just because you can use epoxy to seal this pours wood bowl doesn't mean that doing so is better than making the bowl out of a better material.
Epoxy sealing is a good technique to learn because you may want to do that on "important" (sentimental or highly figured) wood in the future.
robo hippy
>You could try a wet sanded oil/urethane finish. Slop on a heavy coat of finish, and using fine grit abrasive, sand the finish into the wood. Wipe off excess slurry. The slurry will do a fair job of sealing the wood. You will need several coats of finish to seal it, then maybe a surface finish on top of that. A lot of work, and maybe a good no leak bowl when done.
robo hippy
George Van Beynen
>It would make a great fruit bowl Barry, the porosity would be an asset to deter mold.
