>I've been working "big" the last week or so (and man, am I tired!) and I am wondering if there are any things I might be doing to better my chances of work surviving with too much movement or cracking?
Can't avoid a pith. Or two. Or sapwood. And far too big for the DNA bucket (even if I hadn't run it over with the truck...)
Any ideas? The wood is cherry, so it's going to move...
>Cherry sapwood moves more than the heartwood which combined with the pith doesn't make it promising. Bagging it may slow it enough to help some, but then the sapwood is going to be stained pretty ugly.
It's done now, but I would wait for more appropriate material before putting that much work in a piece. I like the odds in my favor. :)
>I turn a lot of fruit-tree orchard Cherry and that wood is worse than the wild cherry because there is more sapwood and smaller diameters. That makes it nearly impossible to turn anything large without it having heartwood, sapwood, and pith in the same piece, but I do it all the time because the wood is readilly available.
The only way I have been able to save it is to turn it to a final thickness of no more than 1/4" while it was still wet, and keeping it wet so it won't move while it is still in the lathe. That way the wood is free to move as it wishes as it dries. There can still be some minor cracks, but they are very small, and usually there are none. The only downside is that there is no way it can be spun on the lathe again. It will have to be power sanded with the lathe OFF.
Turning the bottom and removing the chucking spigot can be a challenge after it dries. I choose to make these make these with a round bottom with no foot, and turn the round bottom to the same 1/4" thickness while the wood is still wet. That way there is no extra spigot thickness to cause stresses and cracks.
To do the traditional rough-dry-finish turning sequence requires a lot more than the usual 10% thickness, more like 25%, and that extra thickness causes more cracks than can be filled.
The final shapes are always interesting, but most people who see them appreciate that it is wood and that wood moves. The grain patterns can be spectacular. With a little planning, the tree can be sut to get the ahape and grain that is most attractive. They sell better and at twice the price of a geometricly perfect form, so I think they are worth the extra effort.
>Steve, what shape are you turning? I am liking the wrapping method more and more. Wrap the outside, and leave the inside open. I am using the stretch plastic film for hollow forms, and paper and the stretch film for the outside of bowls, covering the entire outside, and leaving the inside open. If you want to do the DNA soak, you can put it in a large plastic bag, one that doesn't have holes in it, and saturate the wood which is close to soaking. If you haven't heard this one from me before, on green woood, turned to final thickness turnings, the soaks (DNA or LDD) do nothing that I can observe or measure.
>DNA and luck might stop the cracking, nothing will stop the warping of cherry. By the way for big pieces I use an ice chest cooler type thingy. the friction top keeps the DNA from evaporating and it is large enough for a real big piece of wood.
The form in question & a little something else :-)
Steve antonucci
>Here is the form in question. It is almost dry with the exception of the bottom below the light ring. I will hand sand the entire vessel next weekend, and probably spend a fair amount of time regluing bark (I just put 3" back on in a 2.8" hole...) Once I finish sanding, I will bleach the sapwood white again and final sand.
Waiting for questions on the other little something else... :-)
Re: The form in question & a little something else
Steve Kubien
>Looks like a cross between a captured rig ala Lyle and a free-hand system ala Ellsworth. Steve, you've always been kinda hardcore about hand-hollowing. Are you going soft?
>I wanted to challenge myself today. I actually turned the entire form hand held Friday night and Saturday morning. Today, I wanted to see if I could make a "system" that addressed one requirement: it had to be "free". I could not leave the shop to buy anything that I didn't already have on hand.
I succeeded, and I will admit that it works pretty darn well for something that took less than 90 minutes to make. The two things that hollow turners struggle with the most are staying on centerline and measuring. I have a laser pointer pen that someone gave me at a tradeshow, so you can bet that I can rig up a laser if I want to without spending any capital.
At some point, I'll probably write an article for how to build this thing from stuff you having laying around the shop. There is absolutely no reason to make it captured, as it would be ridiculously over-engineered if I did.
>Simple and elegant solution. Would make a good platform for a router jig for fluting, etc., the outside of a piece.
Working BIG seems to involve a lot of work - and a bit of pounding on the hands. Other than Becasue I CAN! - why go BIG or REALLY BIG? Seems like the Reward To Effort Ratio - to say nothing of the Reward To Risk Ratio - is awfully low - though in this case it looks like things paid off.
