new Jet 1642-2 adjustment
Bill Tucker
>Afternoon ya'll,
Have a beautiful new Jet 1642-2. With a safety drive in the headstock, and a One-Way live center in the tail stock, the points don't quite match up - about 1/16 off, side to side. Is this fixable, and how??
thanks,
bill tucker
bill.tucker@att.net
Re: new Jet 1642-2 adjustment
>Bill Try leveling the lathe first, front to back and side to side. Sometimes an uneven floor will twist the bed enough to throw the centers our of align. You might also check to see if everything is clean. It doesn't take very much grit under the tailstock or headstock to throw them off.
Russ Fairfield
>You did say the misalignment was side to side??
Those lathes have a sliding headstock, and it may swivel as well (I don't remember). Either way, there will be some slop to allow for the movement, and the Jets I have seen had a lot of slop. Loosen the headstock lock and pull it into alignment and lock it again. That works on all of them I have used. If it doesn't, call Jet.
Rick_Allen
>Before I would suspect the lathe I would suspect the procedure used for checking alignment.
As John said check that the lathe is equally supported on all four legs. This is to say that the weight supported by the right front contact point should be the same as the right back contact point. Left front should equal the left back.
The procedure I would use is:
Remove the drive center and the live center.
Inspect the inside of the headstock and tailstock quill
Insert the drive center in the headstock spindle and the live center in the tailstock.
Mark the drive center and headstock spindle with a sharpie. This will enable you to remove the drive center and reinsert it knowing if you are in the same position ot some other position.
Mark the live center with the tailstock quill in the same way.
Mount a piece of stock between centers, lock everything down apply pressure by advancing the tailstock quill. Run the lathe at a good and safe speed while applying pressure with the tailstock. This will help insure that the centers are well seated in the headstock and the tailstock.
Now that the centers are well seated, move the tailstock up to check the alignment.
Remove the drive center and insert 90 degrees from where it was. Seat the center as you did before and check alignment.
Do this two more times 180 degrees and 270 degrees.
Do the same procedure with the live center.
This procedure will help insure that the centers are accurate. If you have access to other drive and live centers try them out as well.
Because your headstock moves you should test locking the headstock at different positions along the bed.
The point is that you want to be positive about the alignment issue before you make adjustments to the factory set condition of the lathe.
Please note that the centers might not line up but the headstock spindle may be aligned with the tailstock. It is possible that the MT is not centered in the headstock spindle. You need a dial indicator to check this.
Good luck
>To reiterate what John said.
I had the same experience with my Jet after I moved it. I just took the wrench to the levelers (on the instructions of the Jet service guy) and "tweaked" the center points into alignment. You have to make sure the tailstock quill is out about half way.
Philip Morris
>Bill,
I have a 1642 that had the same condition. There is some flex in the lathe that will cause it to conform to an uneven floor, which will result in the points going out of side to side alignment.
If you are using the adjustable feet that came with the lathe, all you need to do is adjust one up or down until the points line up. In my case, I needed to raise the lathe several inches, so I built some tressle feet similar to he article Dominic Greco has posted here on WC. I used some 1/8" shims under one foot to get the points to line up.
Since my feet were 4" x 5.5", there were still areas of the feet that did not have full contact. I just place a piece of 1/8" rubber gasket material under each foot to ensure even pressure on all of them.
Lathe is now very smooth and points line up.
Re: new Jet 1642-2 adjustment------WebKitFormBound
Bill McWhirter------WebKitFormBoundary4GeHIDIwv+yG
>As unlikely as it might seem, the bed on the 1642 will torque. I had the same problem, only much worse. Just adjust the casters (tailstock end is the easiest) and you can get it "spot-on."
------WebKitFormBoundary4GeHIDIwv+yGf18c
