modified the jet a little
Marc Phillips
>Been puttering in the shop... basically delaying the inevitable cleaning I have to do before I can turn again... maybe
The spindle lock on the Jet is spring loaded... a safety feature for sure... if it engaged while turning obviously that would be a bad thing... but it is nearly useless since the button pops out when you need the spindle lock engaged, basically making it useless... in my opinion anyhoo.
4 self tapping sheet metal screws later is works real well now.... a very simple modification but I like it. The worse thing that could happen is I could turn it on with the spindle lock engaged and burn up a belt... not a catastrophe and unlikely as I have been using this for 3 weeks now and no problems at all.
The other thing is the simple plywood wrench looking thing... it is a tenon sizer so I can see if a tenon is too small or too large for the chuck before I have to move the tool rest, tailstock, and on and on...
Anyway... wanted to share
