THE WOODRAT IS BACK!
Need source for large nuts
Chip in Plano
>I need a source for 1 1/4x8" nuts to make some chucks. I couldn't pass up the 20% off deal at Woodcraft so I picked up a 3520b...lucky me they still had one with the free bed extension, too. Such a deal.
Anyway, I don't feel like dropping $60-80 on faceplates right now and I'm not that keen on the male/female adapters just so I can keep using my 1x8 faceplates that I've collected for my smaller lathes.
Re: Need source for large nuts
Skip Beardsley------WebKitFormBoundarylsHY4+4w161B
>Check out any heavy equipment repair shop in the area or any tractor dealer. I have had no trouble getting them at places like that.
Rob Wallace
Rob Wallace
>Chip:
Congratulations on the new Mustard Monster!
Be careful about NOT getting 1-1/4" x 7 (seven threads per inch) which is MUCH more commonly available. In my experience, most "normal" distributors of hardware (especially Grade 2 hardware) have the 1-1/4"x 7 tpi nuts, but not the 8 tpi version required for your spindle.
You can try McMaster-Carr (ordering available online - Google company name)...
You are looking for # 90521A275 - 1-1/4"-8 tpi; cost $ 12.50/pack of 5
Hope this info helps....
BTW - If you haven't gone here yet, have a look at:
http://mustardmonster.googlepages.com/
Have a great weekend!
Rob Wallace
Texian
>If you need some inexpensive faceplates, try Noble Associates. He makes them from nuts welded to flat plate. Suggest you spend a few $ extra to have them faced off.
Bill Crommett
>Check out FASTENAL.com
Re: Need source for large nuts *LINK*
Fred Holder
>I purchase 1-1/4" x 8tpi nuts from MSC. You have to purchase a dozen or so, but the price was right on the last bunch that I purchased. Incidentally, you may need to insert a washer between the nut and the shoulder on the lathe. Pressure must be brought against the shoulder to make the faceplate run true.
MSC's Web Site
robo hippy
>Granger also has them, the locking type with the nylon insert, which stick out farther. I use a 2 part epoxy to seat them into a waste block, and you can find syringes in the wall paper section of your Ace/Home Depot/ etc. stores to squirt the epoxy into, mix with a bamboo shishkabob skewer, and squirt into the hole. Much better than mixing and trying to drip it in after mixing on a lid or whatever.
robo hippy
McMaster Carr *LINK*
Mike Cunningham (Cape May NJ)
>I've purchased them from McMaster Carr, in fact not two hours ago I gave three 1 1/4"X8's to a friend. They have good pricing as well as very fast shipping. See the link
McMaster-Carr
