Heat Bending
Heat Bending
Heat Bending
charlie belden
>A Michael Fortune article in a recent woodworking magazine on Steam Bending - using a 3" threaded pipe flange, a short piece of 3" threaded on one end pipe, fiberglass insulation, and a propane torch - for heat bending wood - got me wondering.
He was soaking quarter inch thick flat strips - in a section of capped on the ends rain gutter - then bending them on the hot pipe - to form seat back slats. Apperently, the heat softens the lignin (?) [the wood's natural glue to hold everything together] and allows the wood fibers to bend without tearing or breaking.
So I'm wondering if this idea could be applied to thin walled pieces - to deform them, in a semi-controllable way - perhaps to do concave or convex surfaces on an already curved surface? And if you started with green wood anyway . . .
Just thinking "out loud".
Anyone with any experience with this sort of thing? Any idea of where one might find the special thermometer - apparently temperature is important for the technique to work?
Re: Heat Bending
Steven Antonucci
Google Guitar making and you'll see tons
Steve antonucci
>This is a well known technique for bending the sides of a guitar... boatloads of info available.
Steve
Re: Heat Bending
Re: Heat Bending
>I did that to make some handles but I really jury rigged the torch and had trouble keeping the temperature cool enough not to scorch the wood. It might work on a green vessel, who knows.
Re: Heat Bending
Re: Heat Bending
Michael Mocho
>Hi Charlie,
I've been bending wood using the 'hot-pipe' methods for over 30 years.
In addition to building stringed instruments- mostly guitars- I have also incorporated bending with turned components- (images attached). It's been a great technique to add to the 'creative arsenal', and I will be including it in an upcoming class at Arrowmont with D.E.
One of the critical factors in this type of bending is that the wood fibers need to run as parallel to the surface as possible- pieces with run-out will tear apart, so most turned forms may not work, unless they have straight sections with long grain. Years ago there was an article in the journal describing a method of bending green turned hollow forms by boiling them- you may have better luck with that bending method.
A thermometer isn�t essential, though it is important to judge the heat properly- I can best describe it as �hot as a pancake griddle�: a drop of water should sizzle on the hot metal surface of the iron, but not instantly vaporize. Too hot and the wood will scorch once the moisture is driven out, too cold and the lignin won�t plasticize enough to let the fibers slip by each other to make the bend, and you end up breaking the piece if you force it. Keep in mind: it�s the heat that makes the wood bend, not the water. The moisture only transfers the heat and makes the fibers more pliable. If the wood is heated for tool long, the fibers take on a set, and will become brittle as a cracker. Remove the wood from the hot surface of the bending iron before this happens.
The wood should be as straight grained and the moisture content should be above 20%. Green wood can often be bent without additional water, though kiln-dried stock needs to be soaked if it is over about 3/16� thick, depending on the specie. Pieces under 1/8� thick can often be bent after spraying them with water and letting it soak in for 10 � 20 minutes.
I find the flat-sawn wood bends better than quarter-sawn, and some woods with interlocking grain (certain types of mahogany) tend to rupture rather than bend. Maple, walnut, cherry, ash- all bend easily, as do many exotics. Figured woods and burls are very tricky, and I suggest you experiment with wood that you have little emotional attachment to.
Good luck / Hope this helps.
-Michael Mocho
P.S. due to mysterious computer weirdness, my website is a mess right now, but you can see a few images of work that incorporates bending at:
www.mmocho.com
Re: Heat Bending
Re: Heat Bending
charlie belden
>I'm thinking along the lines of scalloped rims, partially rolled rims, Terry Scott rolled corners pieces, maybe rippled surfaces on a hollow form, shallow creases, hemispherical depressions on an otherwise flat platter (a shallower, less defined type ofdepression you can do on mulitple centers, or by carving/griinding/sanding), . . . Just looking to get away from round symetry on one axis.
Re: Heat Bending
Great Info - NICE Piece?
charlie belden
Re: Heat Bending
Steam Iron?
Al Kapocius
>Howbout using a steam iron (controlled temperature) on a thin wet piece then promptly compressing in a form?
Al Kapocius
Re: Heat Bending
Re: Heat Bending
>I use the cooking thermometers found in the grocery store. The small dial type work well - make sure it will go to more than 220 F.
I have bend around forms using a hot water bath. That works well (shaker boxes). I have bent using my steam box. That works well. I've used the heated pipe once or twice. I need to work on that technique.
Re: Heat Bending
Controlled Heat Deforming
charlile belden
>I guess "bending" gets you thinking just in terms of a flat piece of wood being bent. I was thinking of ways to deform SOME of a turned piece - a scalloped or "pinched" rim, "blisters" in the sides of a piece, curled corners of a square bowl or platter. There are crimping tools used on stove pipe sections, two piece leather dies.
Captured hollowing systems, like Dick Coers $30 version, with laser, could be adapted to hold part of a die set, a ball on the inside, a complimentary "cup" on the outside, the laser pointing to where the "cup" should be applied and pressure exerted. Or something like a combination caliperwith a cup on one leg and a ball on the other, - with electric heating element built in - like on those branding irons to burn your name on flat work.
Re: Heat Bending
Re: Controlled Heat Deforming
Bob Ingram
>I used to do shoe repair we had a pliers looking thing to put a dimple in leather for corns...It has a ball on one and a loop on the other you might be able to heat this it was made of iron and use it ...check with an old time shoe repair guy
Re: Heat Bending
Re: Heat Bending
Ace Foster
>For the thermometer, look at Ace (or in your neighborhood, OSH), in the heating section. Generally you'll find them near firewood racks, fireplace tools and that sort of thing. They commonly get used on the airtight woodstoves that are so common now.
Ace
Re: Heat Bending
Re: Heat Bending
charlie belden
>Thanks to all for the insights into what the wood is doing as it is heated and ways to utilize that information to shape it.
Don't know when, if, or how Ill try and use it, but I suspect there are some interesting possibilities for applying it somehow to turning.
I envy the options that pot throwers have which are difficult, if not impossible, to do with wood and a lathe. On the other hand, we have all the interesting things in the wood. Imagine if wood could be made more plastic - and thrown - on a wheel - then "fired".
