>I had a tree go down on my property over the winter and just identified it as American Linden or basswood. I know that carvers like basswood which makes me think of it as a really soft wood with little character. Any experience with turning it? I would be tempted to use it for altered forms (as in carved or burned) if it isn't too soft. Anyone turning basswood?
>soft wood with no character but it does turn nice. I have 3 longs leaning against the garage that I'm going to try to split and cut into turning/carving blanks. It's already started to check pretty bad so I'll probably have to cut it into smaller pieces than I originally wanted.
>I like basswood for use in jam chucks and other sacrificial uses. while the wood is pretty bland, it's not bad with some darker stain on it. Just a couple of thoughts from here.
>As the others have pointed out, it is extremely bland in appearance, having almost no visible grain. That said, it turns beautifully, taking detail while turned the same as when carved. As a practice wood, for practicing some of the more difficult coves and beads, it's tough to beat. Just about anything you can do to it when carving, you can do turning: carving, piercing, burning, what ever.
>Basswood really suprises me on how hard it is to dry. It will check very easily in larger blocks. Being that soft, I would have thought that it would dry easily. Darn it!
>I've never turned it for anything meaningful, but I do carve it frequently. One of the most notable features of bassowrd is it's ability to hold detail in carving with a clean edge. At a minimum, I'd slab it for carving some day.
>I guess I'll have to harvest some of it. The tree is still alive and I'll have to wait till winter so I can get into the woods with the tractor. It's too wet there now. I had a feeling that it would be good for holding detail and with my recent interest in carving, I'm gonna have to try it out. Thanks all.
>There is always a problem with the answers you get from asking such a question to a forum such as this one. There is almost no comparison with the wood from the same tree that grew in the SE, the NE, or above 5000' elevation in North Idaho. The only thing they share is the name. There can also be large differences within a region because of local soil conditions and weather patterns.
American Linden or common basswood can vary from the soft, light weight, light colored wood that others have described here; to a heavy dense wood with a dark green/brown color and a strong visible grain pattern. You will have to cut down your tree before you know which one it is, or if it somewhere in between.
I've turned a little Basswood, and while the stuff I had was pretty bland, I wanted to turn wide-rim bowls and platters so my wife Linda could try drawing, wood burning and carving on them. I found it turned pretty well, most like white birch, with a peppery smell. Like Russ says, the color and texture you get may vary, but the batch I had was very fine grained.
