Dick Coers - Articulated Hollowing Rig
GalenV in Iowa
>Dick:
Although I am not finished I thought I would show you where I am at on your articulated hollowing rig for adapting to my Jet 1220.
The 3/8" tees and 5/8" bolts came out really close to puttng my cutter on centerline. Only pipe nipples I had were 5" and 2 1/2" and think they need to be shorter. I used a few more nylon bushings and need to turn them down. I have a foam bike handle I will slip over the hollowing mounting pipe it needs to be tapped for set screws to hole the bar.
I think it looked like you may have put a spot braze on the tees to prevent turning. I will lead in or pin when I think I got better nipple combination. My maple bed adapter may end up too light but it fit the height.
May find this is all too light to be stable but hey it kept me busy.
Got any more comments on how yours is working out?
Thanks for posting idea.
Galen
Re: Dick Coers - Articulated Hollowing Rig
Steven Antonucci
Just CA glue the T's
Steve antonucci
>They won't move. I've done it before.
Steve
Dick Coers
>Looks great Galen.
I mounted my laser tonight. I also moved the pivot off center, away from me, to work at getting more travel to get through the hole and under the top of the vessels. I'm off work for the next 4 days, so should get some serious test time.
You should get some test time for yourself before shortening the pipes. I think I worried more about the swivel during buildup, than I will use during cutting. We will be making a lot more straight movements than pivoting. Time will tell. I did braze the pipe in. I probably should have done some cutting before doing that. I don't know if the torque will try to loosen the pipe thread or not. I think your base will be plenty strong
