Actual Movement - Inspired by a Classic *LINK*
charlie belden
>Thanks to John Veerkamp for the inspiration.
Don't know if I'll get to making this one a reality - but it's kind of fun to plan.
THING (think "Addams Family)
charlie belden
Re: Actual Movement - Inspired by a Classic
Don Evans
>Charlie:
You need a vacation man!
Seriously, if you cut a half round in the right spot on the edge of the cam, you can use it as the stopping point for the motor. Set a micro switch so the half round cutout allows an arm to fall into it, the arm is attached to the switch so it opens and stops motor.
So how do you get it to go, only way I see at moment is to have a button that activates motor, if wired correctly, you'll hold down the buttom until the motor moves the notch (half round cutout) enough so micro switch is closed, you can then let switch go and it will continue to make one revolution until the switch opens again at the notch.
What size box are you thinking?
A motor like one's used in model railroading may work. I can see this getting expensive real quick. If you want to keep it small 6"x6"x6" say, them you'll probably have to convert from AC to DC to run components.
Check out:
www.micromark.com
Don
charlie belden
>Don:
You're still thinking conventional, fast becoming Old School, motors. Having played with HexBug's stamp sized programmable processor controled stepper motors (or servo motors) - with one or more sensors - you can control - and vary - the rate and amount of rotation - as well as the direction or rotation, more possibilities have opened up.
I've dismantled the CRAB bot I accidently super glued a critical joint together so I've got the motor, with a screw gear on its shaft - the motor is still wired to the controller board and I've got some old servos from my RC daze that could eliminate the need for the cam.
Don't know if this idea will ever make its way into an actual piece or not. Just throwing out an idea. And who knows, someone may find a way to use it for a turning - or not
Picked up a spring driven mechanical Bot that has eccentric weights on its rotating shaft. The resulting vibration from the rotating eccentric weights could get a larger piece to move around randomly - and make a buzzing noise. If I can replace the spring drive with a small battery powered DC motor - and figure out how it can be turned on and off remotely - I can have movement AND sound.
Where I seem to be going with all these ideas is the blurring of the boundaries of traditional and current turnings. Single axis symetry limitations are being gotten around with multi-center and eccentric turning. And smooth surfaces aren't a limitation either, what with pyrography, texturing, gesso, carving, scortching, sandblasting, etc. While there are people doing actual dynamic pieces, they're currently few and somewhat far between.
There's a lot of digital technology out there waiting to be applied, and exploited (?) in "creative" ways (there's a fine line between "creative" and "gimmick" - and it's at the fringe where the fun is).
As for the need for a vacation - summer vacation is around the corner and kids will become a distraction, albeit a really fun distraction. And when The Muse starts throwing out ideas you go with it 'til the vein of potential gold runs out. When the fun and "interesting" drops off, so will I. So far that hasn't happened.
