Prototype of a "new" process
Steven Antonucci
Steve antonucci
>Now comes the big reveal...
Here is something I have been messing with for a couple of day. The finish is a wax based pigment that is applied to the wood with a random pattern to create the chaotic, yet somehow structured, finish you see here. This is a prototype for some work I may be pursuing now that I have the technique figued out...
It's not a finished piece, so I'm not so concerned on whether you like the object, but what do you think of the effect? I'm probably not done playing with it yet...
Steven
Re: Prototype of a "new" process
Steven Antonucci
close-up
Steve antonucci
Cyril Griesbach
>It appears to be an interesting process, Steve, and I'm intrigued. While the application on this piece as a whole seems much busier than needed the closeup provides great interest and shows depth in the result. Will there be more information forthcoming?
Re: close-up
>I agree with Cyril. It seems a bit too busy with the grain. Maybe if you didn't use a wood with a prominent grain?
keith zimmerman, Normal IL
>It reminds me of fingerpainting. This process might be useful on a wood that has no distict grain. I agree that, on this wood, there is too much going on with the grain and there is a lot of conflict going on and neither the pattern or the grain is prominent. I think it needs to be one way or the other, not both.
I would like to see what it looks like on a wood with no prominent grain before I can form a definite opinion.
keithz
Bob Moffett
Bob Moffett
>I really like the effect. It will be interesting to see it when it is completed.
Don at Central Illinois
>Before I click to enlarge, I really like it, but looking at the close up,it seems too busy. Maybe less is more. I really like the concept, but think you went too far. I realize this is a practice and you have to get the technique down before you can make a finished product. Looking forward to the end result.
Sean Troy
>Being waxed base, what type of finish could you use on top of it. ?
Keith Tompkins
Keith Tompkins
>Hey Steve, I like it. It would be interesting to see a coat of white gesso underneath. Perhaps sections of a turning with this technique, with the rest natural wood.
finger painting,yes
>I like it also. It has that unstructured feel of a child playing. Maybe your getting in touch with your younger self. :)
Don Orr
>I like the color palate of this piece and the overall technique. Might need some refinement yet. As a first trial though it looks like it has a lot of room for experimentation-right up yout alley !
I presume this is the piece you were asking about finishing over wax. I still think shellac would work since it already contains wax. And Russ says in his "Woodturning Design " article that shellac sticks to everytning and everything sticks to it.
Steven Antonucci
Some more information
Steve antonucci
>Thanks for all of the comments so far.
Yes, this is my wax based finish. The color palette was co-decided by myself and my daughter, although I have to admit, the work is mine. I had asked her to do the color work, and I got a couple of triangles so I had to take over...
The wood isn't necessarily suppose to show the grain through the color, and I'm not sure why it appears so prominent in the enlarged photo? It is nowhere near that obvious when viewed in person. Also, the color is quite a bit more intense in person than the photo shows.
Not quite fingerpainting, but close...
And I agree that this is a piece that requires some distance. It is much more interesting as a whole than it is at inspection. Quite possibly, this piece needs to be 2-3x in scale to really be successful, and I will be playing some more in the coming days...
Thanks
Steve
Paging Mr. Stafford, please bring your...
Re: Protective coating
Russ Fairfield
>Ah-ha, you are looking for a "protective coating". The phrasing of your original question got everyone into thinking "finish", when it should have been "protective coating". There is a difference.
Your best bet would most likely be Krylon Workable Fixitif. Try it and see what happens. Apply several very very light coats. Hold the can way back from the surface so the spray droplets are almost dry as they settle on the surface. What you will want is like a cloud of overspray settling on the surface. Do not "wet" the surface. That wetting will be the solvents on the surface, and they can melt your wax.
You can do the same thing with spray can Deft in the lowest gloss they make. The difference is that damage to the wax and a visible surface film will be more likely because the slower evaporation of the solvents in the Deft will make it more difficult to apply as a light and dry coating, and it is more likely to damage the wax.
Sorry it took so long to get me thinking in the right direction. ntioning it sooner.
Re: you could also use....
Russ Fairfield
>Another option is a spray application of shellac, but I don't know of anyone making shellac in a spray can that is worth using these days. You might check the Zinnser Seal-Coat at Home Depot and see if it is available in a spray can. I have no idea if it is. Shellac will have a higher gloss than the matte lacquer.
Texian
>The process is obviously way cool, if you can develop a suitable protective finish layer. Semi-infinite possibilities, with the merit of any specific piece depending upon the artistic vision of the person(s) doing the fingerpainting. Perhaps a good vehicle for some collaborative projects.
Prototype of a "new" process- "Antonucci Paisley"
GalenV in Iowa
>Same colors of a paisley shirt I had many years ago, but then it changed color about every wash.
Bob Macgregor
>A fingerpainting impression of intestinal parasites, in coloured wax?
I think there is a lot of scope for creativity, though. Still, I'll stick to natural woodgrain until I get bored with it...which shouldn't be for quite a while.
BOB
Re: close-up
Dennis Yoder
>Great effect Steve, the subtle mixing of vibrant colors and shading with the soft outlining reminds me of some tattoos I have seen. Dennis Y
charlie belden
>Pollack using ribbons rather than paint!
Having looked at the Long Shot and the Close Up I can see you've got a lot of possibilities to play with. The 3D shading gives a flat ribbon appearance. Add color and even more possibilities open up.
It's interesting when Art Supplies ideas and wood turning come together - some good, some not so good. This one looks good - and with some Vessrey (sp?) sensitivity to color combinations and glazing . . .
Look foreward to where you take this idea and technique.
