REAL MILK PAINT
Aniline Dye Finishing Process
Dan Oliphant
>Could someone share the process details for using multiple colors of aniline dye on turnings? Has the process been documented and I just haven't found it yet?
Re: Aniline Dye Finishing Process
RonZ
>I learned it from Jimmy Clewes. He has it documented on his video.
You use alcohol based aniline dyes. First you put on denatured alcohol via a spray bottle to raise the fibers and get the wood ready. Jimmy likes to ignite his or you can use either 0000 steel wool or a white 3m pad to ct back the nibs. You then dab on the colors you want in the area you want. One point of the alcohol based dyes is that it should dry fast and not run.
>They can also blend if you overlap them, yellow and blue make green, etc. There are so many ways to do it. Wipe on or airbrush, each has advantages. I buy red,blue, yellow, and black and can mix any color I want. I use a lot of greenish or brown so I also bought those colors.
If you let each color dry inbetween coats you can sometimes put one color over another and then steel wool through them when dry which is a nice affect.
Cyril Griesbach
>Dan, the mini group in our club has been playing with dying lately and this is what I did at Monday�s gathering. It�s a Big Leaf Maple Burl bowl that blew up on me some time ago and I put it in the try to save/experiment department.
I sanded it to 400 grit first making sure there were no tool or sanding marks as these will be greatly enhanced by the dyes. Then blue dye was applied and well sanded back with 180 grit. Then red dye applied and sanded back with 280 grit and followed with yellow dye and sanding to 400 once again. I used alcohol based Artisan dyes from CSUSA allowing the alcohol to evaporate and the dye to dry between steps. Starting with the darker colors first and sanding them back attempts to enhance depth to the piece. It has only one coat of wipe on poly so far and I hope to bring it to a higher shine.
Burls and end grain pieces work well for this but applying this to a side grain piece will give you a pronounced light streak on the side grain as it does not take the coloring as deeply as end grain.
Lots of folks doing this so I hope we both learn more from your question.
Dan Oliphant
>After looking to the guitar world and their finish processes along with the limited process data available in the turning world concerning the use of aniline dye for layering colors, I believe I have a good basic process defined.
I have several hollow form turnings that are from sycamore, eucalyptus and ash that will be ready for final turning within the next few weeks, the basic process will be fine tuned on these turnings.
I will write up the process in detail and share it with all that are interested.
Re: Aniline Dye Finishing Process *LINK*
Cyril Griesbach
>Dan, I would also direct you to this article right here on Wood Central in Russ's Corner on using dyes.
Coloring Wood Turnings with Aniline Dye
Dan Oliphant
>Cyril,
I had already located that write up, but thanks for the link. I believe what is missing in that process is the requirement to start applying the darker color dyes earlier in the sanding process. We will see.
I just finished a pair of wedding goblets that were dyed black using aniline dye, these goblets were sanded to 400 grit then dyed. The dye cycle required nearly 8 hours of submersion before the ash was black enough for me. Dye concentration was 2 oz. to 3/4 gal of alchohol, (volume was required because the pieces needed to be submerged.
>I apply the darker colors first, just like in airbrushing. This way you can run into a darker color with the lighter color and not change the two, unless the bleed together to form another color.
I use shoe dye for my black colors. it goes on with less coats to make a really good black. I use the aniline dye when I want to have a blue black or a reddish black. You can change the color of the black very sublty.
Dick Hines
Dick Hines
>Cyril, I am glad you went to the trouble to "save" this bowl. It is one of the nices pieces I have seen posted in some time.
Hope you "save" some more of pieces.
Re: Very rich color combination Cyril.
Jamie Donaldson
Cyril Griesbach
>Thanks, Jamie.
Joe Flemig
>Dan,
I documented coloring techniques with an emphasis on Don Derry's method. The handout can be found at this link:
http://www.sdwt.org/support_docs/techniques&tips/coloring.pdf
Joe Fleming
Russ Fairfield
>Try to find a copy of Jan Sanders book, "Coloring Techniques for Woodturners" or the video of the same title. It is the best source on coloring and dyes that I know of.
Both are out of print but they are sometimes available on the used market, and I have seen the video in the woodturning catalogs. There is a good chance of finding either or both of them in the libraries of most AAW Chapters.
Chris Stott also did a video on coloring, that might be easier to find in the catalogs.
Dan Oliphant
>Thanks for the input everyone.
Cyril Griesbach
>Dan, the mini group in our club has been playing with dying the last few times we met and here is what I did at Monday's gathering. This is a Big Leaf Maple burl bowl that blew up on me a while back and went on the try to save/experiment pile. I sanded it to 400 grit and then applied blue dye...sanded the blue well back with 180 grit and applied red dye. The red was sanded back with 280 grit and yellow dye was applied and then the piece was sanded to 400 again. The sanding back and starting with darker colors and progressing to lighter colors attempts to add depth.
This works on burls and end grain because the whole piece takes the dye penetration most evenly. Doing it on a side grain piece will leave a MUCH lighter streak of side grain. I used alcohol based Artisan dyes from CSUSA. Allow the alcohol to evaporate and the dye to try between steps. It has only one coat of wipe on poly so far and I hope to bring it to a higher shine.
Lots of folks here are doing this so I hope we both get more information from your question.
