Vacuum Pump--Revisited
Dennis in Southern Oregon
>A couple of days ago in response to Jorge Castaneda's question, I pointed out that the true gauge reading for an ideal vacuum pump is equal to the barometric pressure at that location and altitude, and that it can be over 30 inHg. A sea-level pressure of up to 30.2 or 30.3 is not unusual.
Later, it occurred to me that there is another aspect of barometric pressure that can cause concern to someone trying to set up and evaluate a vacuum system. That is the fact that barometric pressure decreases rather sharply with altitude. From sea level to 10,000 feet or so, the barometric pressure decreases by about 1 inHg per 1000 feet. Therefore, if you live at an altitude of say 5000 feet the average barometric pressure will be about 24.9 inHg rather than the sea level value of 29.9 inHg. Therefore, before you tear out your hair trying to find the leaks in your new system take into account your altitude. A side note: there won't be many vacuum chucking systems sold in Tibet. :) Dennis
Re: Vacuum Pump--Revisited
Death Valley -Vacuum Chucking Capital of US
Bill Howatt
Wilford Bickel
>Interesting Dennis - early this year we bought a small "weather station" to put in at the farm for helping with feeding the cattle due to wind chill and such. One of the installation steps was to go on the web and find the nearest NOAA location or airport to your location and reset the barometric pressure to match. We had a local municipal airport about 10 miles away and if my memory serves me we are between 600 feet and 1000 feet above sea level here and I had to make about 1 inch of Hg change to calibrate the unit. This definitely is something to keep in mind when using vacuum - my unit pulling 27 would be right at 28 on the coast and that is not bad for a pump system! Good facts Dennis!
Russ Fairfield
>Fortunately I will never have to worry about such things because I am using an old milking machine pump from the farm, and they pull only 17.5"Hg. The only difference is that I have to use a larger chucking area, but that has never been a problem, and I can still suck in the bottom of a platter if I'm not careful.
I think woodturners worry too much about trying to achieve as close to a perfectg vacuum as possible, when a lot less will do the same job.
>Ditto I rarely use full vacuum. Usually around 15 to 17". I only use full vacuum on very small pieces. I use mostly a 6" vacuum chuck and it will hold really large things with 17".
Russ Fairfield
>My favorite vacuum chuck for bowls is the one that Vic Wood used to make (now sold by Vicmarc), and I use my shop vacuum. That is about 5"Hg. but it works because the the greater square inches under vacuum. The result is a force in excess of 500 pounds holding a 12" bowl in place, and that is more than enough. It will also suck the finish out of the inside of the bowl if it isn't fully cured and dry.
Bill Howatt
>I agree. I was only able to pull about 6" Hg on my last job using a 6" diameter drum chuck and it was just fine although I would have preferred a bit more cushion.
Bill
