REAL MILK PAINT
What do you do if...
Don Orr
>...the piece you are workig on is longer than your lathe can accommodate? Why you line up your mini lathe and weight it down with an anvil. Add in a steady rest to manage some of the whip and there you have it. This is a ramming rod for the cannons on the Onrust and it is over 4 feet long. I had to turn down the shaft diameter to �� x 2� long and add a 1.5� diameter head about 3� long with a taper down to the shaft size. Worked reaonably well. The gun captain was very pleased with the results.
Re: What do you do if...
Dick Coers
>I like the way you think! Very nice.
Nice job- I did the same for a long lamp
Texian
>Nice work Don. Like your chip chute to behind the lathe.
Bill Grumbine
Barbara Gill, Remlik VA
>You should go to Bill Grumbine's site and look at the arrangement he made to turn a mast. I think it was about 5 years ago but I could be wrong.
Bob Macgregor
>There is a video in the "miscelaneous" section of the Woodworking Channel videos page that shows Nick Cook turning a very large oak log into an hourglass-shaped coffee table. He used two PM3520's held together with pipe clamps. He used two lathes, not because of the length, but because the diameter was too big to go over the bed and the weight was such that it needed to be supported at both ends/turned between centers.
If that piece had come loose, it would have rolled over Nick like a steamroller!
BOB
Looks like a Jet lathe promotional ad!
GalenV in Iowa
>If you sent WMH Tool Group the same picture maybe they would feel sorry for you and send you a bigger/longer Jet lathe.
Galen
Thinking outside the tailstock
mfoster
>Nice solution Don. I had a project a couple of years ago with similar requirements and I ended up using a mortise and tenon (round, don on the lathe) joint. This worked for my application, but your solution is a lot better. Wish I had thought of that. I also have a Jet mini and could have coupled it with my Woodfast. I'll remember this next time the situation crops up. Have fun in Pinkerton, wish I could make it.
Mike
Re: For a similar situation some years.......
Jamie Donaldson
>...ago, I fixed my Stubby and General together tail to tail with plywood plates. Allowed turning 4 bed posts in a single piece 78" long.
Re: Looks like a Jet lathe promotional ad!
Don Orr
>You should also see the Jet bandsaw, tablesaw, jointer and slow speed wet sharpener. Yeah I'm a big fan. Oh, Performax drum sander too ;-))
Russ Fairfield
>If you had used a chuck in the headstock of the mini, and pulled tension into the stick with the sliding headstock of the larger lathe, you would have found less vibration and a more stable piece of wood. Try it next time.
Thanks
Don Orr
>I know I did not invent this technique. I have seen it before and just dug it out of the deep recesses of what memory I have left. So thanks to those who came before me and shared so much useful information.
Don Orr
>That would work after I had glued the head to the shaft, but I had to turn a tennon on the shaft first to go into the head and couldn't lose any length.
Your wealth of knowledge is greatly appreciated Russ!
Re: a good reason for having 2 lathes
Russ Fairfield
Jesper, Denmark
Re: Don, the boatbuilder.....
Jesper, Denmark
>...method would have been to start with square stock, plane it down by hand to eight sides, then to 16 sides, plane off the small corners and then sand it.
It is actually quite fast and accurate.
Don Orr
>I thought of that Jesper, probably would have been faster too ;-)) Maybe on one of the other ones I need to do. I have a good drawknife, spokeshave and lots of planes.
